Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Bjorn_K
Thread: How to create lines out of list of points
    April 20, 2018
    19
    04:32 AM
    I'm stuck on a pretty easy problem (hopefully), so I've got a list of points structured on separate lists (L2) (shown below) - the amount of lists in L1 varries, and i want to create lines between each of the point (so for example points [1,0] and [1,1] connected by line, P.[1,1] and P.[1,2] etc...), can someone help with this?
    Attached Thumbnails Attached Thumbnails How to create lines out of list of points-bez%A0tytu-u.png
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    322
    04:32 AM
    Quote Originally Posted by rafalactun View Post
    Lacing, "cross product" comes to mind?
    Sendt fra min ONEPLUS A5000 med Tapatalk
    Member HansLammerts's Avatar
    April 22, 2011
    441
    04:32 AM
    How to create lines..
    lisp
    AutoCAD
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    313
    06:32 AM
    Quote Originally Posted by HansLammerts View Post
    lisp
    AutoCAD
    Might want to go back under that bridge?
    On a more constructive note:
    You will need the Polycurve.Curves Node only if you need the individual Curve segments between your point, otherwise the Polycurve should be enough.
    The connection with the Transpose node is only for the lines going the other direction if you would need those.
    amoursol likes this.
    April 20, 2018
    19
    04:32 AM
    Thanks Bjorn, thats exactly what I was looking for
  1. Replies: 0
    Last Post: June 18th, 2018, 06:15 PM
  2. Create points in etabs using dynamobim
    By Simply Complex in forum Blog Feeds
    Last Post: March 12th, 2018, 03:45 AM
  3. Replies: 0
    Last Post: March 12th, 2015, 06:16 AM
  4. Lines and hosted points
    By Nielsen in forum Architecture and General Revit Questions
    Last Post: December 18th, 2014, 07:06 PM
  5. contour lines and points on toposurface
    By mona miller in forum Architecture and General Revit Questions
    Last Post: December 22nd, 2013, 09:19 PM
