Results 1 to 3 of 3
Thread: Excel IDs --> Generic Annotation values --> Equipment Tags
    August 24, 2018
    3
    09:43 AM
    Hi Reviteers,
    I知 pretty new to dynamo and I知 trying to wrap my head around a workflow for a particular problem I知 dealing with.
    So I知 trying to create a workflow where I import a list of IDs from excel as text strings, then use those as values as options for annotations in a diagram. Then I want to use the same value for an equipment tag.
    I could create a long list of shared parameters for each one but that seems inelegant and the list could be arbitrarily long. I would love any pointers about how to go about this.
    Thanks,
    Aaron
    May 3, 2012
    1,392
    05:43 PM
    ?? Not sure exactly what you want to achieve..I think you will need to draw a diagram.
    For the annotations and tags, what are you tagging? The data should go in a parameter of whatever it is you want to annotate.
    February 2, 2011
    Montreal/Paris
    829
    11:43 AM
    Can you explain the problem, it might help us find the best solution?
  1. Generic Annotation Nested in Detail Item | Select Generic Annotation Type
    By bluebravo in forum Architecture and General Revit Questions
    Last Post: May 29th, 2018, 03:28 PM
  2. Equipment Mark values in Panel Schedules
    By robbbbi in forum MEP - General
    Last Post: December 12th, 2015, 10:46 AM
  3. Annotation Filters - Apply a filter to a generic annotation?
    By JWelsh1990 in forum Architecture and General Revit Questions
    Last Post: November 11th, 2015, 11:27 AM
  4. Replies: 11
    Last Post: October 30th, 2015, 04:19 PM
  5. Generic Annotation doesnt show in Electrical Equipment family.
    By cadmancan in forum MEP - Family Creation
    Last Post: August 8th, 2013, 02:09 PM
