Results 1 to 3 of 3
Thread: Add to space parameter with calculated value from light
    May 17, 2018
    2
    12:57 PM
    I try to add to space a parameter, W/m2 for all my lights of this space.
    my lights 45VA so 34W if 4 lights = 136 W if my space 20m2
    My parameter must by = 6,8 W/m2
    I simply can do that for one space, but I want to iterated for all space
    Daniel OLIVES
    WSP France
    Attached Files Attached Files
    November 21, 2012
    London, United Kingdom
    612
    11:57 AM
    Hello Daniel,
    Have you tried changing theLacing on your Element.SetParameterByName node? Access this by right clicking on the highlighted element, navigating to lacing and choosing 'Longest'.
    Attached Thumbnails Attached Thumbnails Add to space parameter with calculated value from light-revitfourmquery_spacewatts.jpg
    May 17, 2018
    2
    12:57 PM
    Thanks' I try this but it wasn't correct.
    The problem was that I want sum by space the number of light and extract w/m2 after for each space
    Daniel
  1. Workaround to use total count in a calculated parameter
    By davefallow in forum Architecture and General Revit Questions
    Last Post: August 1st, 2018, 01:36 PM
  2. Casework - Add a calculated parameter for cost per linear meter
    By DANNIYOUNG100 in forum Architecture - Family Creation
    Last Post: August 21st, 2017, 03:18 PM
  3. Set calculated parameter of all type
    By Bross in forum Dynamo BIM
    Last Post: March 27th, 2017, 08:50 AM
