Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By cellersick
Thread: Filtering (Areas) by (their) Type properties not working...
    December 21, 2010
    C.LONDON
    4,353
    10:54 AM
    It's a muggy day in London and I've eaten too much birthday cake, so perhaps I'll have a eureka tomorrow with a clearer head - but in the mean time, anyone care / able to shed some light on why the attached (all OOTB node) .dyn doesn't filter output (from all elements) the areas only associated to (in this example) the "Gross" scheme?
    Essentially, we've got 38 area schemes pre-defined in our template - and a minimum of 15 of them get used on all projects. With each scheme demanding a slightly different field concatenation pattern, we need to isolate the appropriate elements (i.e. "go after the areas in the gross scheme and do this").
    But, as ever, tying a relationship between instance and types is beating me.
    'lil help?
    edit graphshot for those who can diagnose without opening...
    Attached Files Attached Files
    September 19, 2015
    163
    10:54 AM
    December 21, 2010
    C.LONDON
    4,353
    10:54 AM
    Quote Originally Posted by Yna_Db View Post
    Could this help?
    Saw that one, not really, unless I'm missing something (?) - it's more the joining/associating the values, not so much reaching in and getting them.
    Gold Coast
    2,602
    07:54 PM
    Dont know the exact node names but you should be able to pull the area instances out of the initial areatype>all elements of type list.
    March 21, 2013
    Phoenix, AZ
    275
    02:54 AM
    I think that graph is going to have problems with the mask matching up with the items correctly - the query driving the bool mask isn't the same query delivering the elements to the bool mask. In other words, you're trying to filter a list of all Areas by asking questions of a list of all AreaSchemes (which don't necessarily share the same index #). Try asking the Areas for their AreaSchemes, and then ask THAT AreaScheme the question about it's name.
    Attached Thumbnails Attached Thumbnails Filtering (Areas) by (their) Type properties not working...-areas_img.png
    snowyweston and amoursol like this.
    September 19, 2015
    163
    10:54 AM
    Same result with Dimitar's script:
    Attached Thumbnails Attached Thumbnails Filtering (Areas) by (their) Type properties not working...-2015-07-31_10-08-19.png
    December 21, 2010
    C.LONDON
    4,353
    10:54 AM
    Quote Originally Posted by cellersick View Post
    That's kinda where I started then I doubled back on myself at some point.... cheers dude.
  1. Family Type Properties
    By rui in forum MEP - Family Creation
    Last Post: March 19th, 2015, 08:23 PM
  2. Measuring wall areas by type, by plot.
    By Glen1980 in forum Architecture and General Revit Questions
    Last Post: November 18th, 2014, 09:08 AM
  3. Material changing in Type Properties
    By willsud in forum Tutorials, Tips & Tricks
    Last Post: June 23rd, 2014, 04:07 PM
  4. Filtering out by Family type in schedule
    By MartinGT in forum Structure - General Questions
    Last Post: January 29th, 2013, 11:30 AM
  5. Problem with type selector wall properties
    By stu1880 in forum Architecture and General Revit Questions
    Last Post: February 24th, 2012, 10:36 PM
