Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Like Tree4Likes
Thread: Script for project files comparison?
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    844
    03:03 AM
    I'm not a dynamo user. But i do have a question. Is it possible to write a script that compares 2 or more open projects and identifies if there are duplicate guid?
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    322
    05:03 PM
    GUID, as in shared parameter GUID?
    Quote Originally Posted by biff View Post
    Sendt fra min ONEPLUS A5000 med Tapatalk
    June 13, 2011
    Australia
    844
    03:03 AM
    Sorry, I actually meant the ID number for each element.
    February 6, 2012
    322
    05:03 PM
    oh, that's the BATID.
    The Element.Id node will get that for you.
    I don't use Dynamo on a daily basis, so someone correct me here; you can only have dynamo look into one project at a time. So a workflow would be to open the two files one by one, and extract all the BATID's in two steps. Export them to an Excel spreadsheet, and find duplicates there?
    June 13, 2011
    Australia
    844
    03:03 AM
    Thank you for your thoughts. Sounds like what i need. So on multiple examples of the same project can i zero in by dynamo on the same components to compare their id? E.g. The north fascia? Big call maybe.
    February 6, 2012
    322
    05:03 PM
    script could look something like this:
    this would require you to select all the model elements in a 3Dview, another alternative would be to grab the elements category by category, that's what the four nodes below is for.
    Attached Thumbnails Attached Thumbnails Script for project files comparison?-2018-08-14_1127.png
    biff likes this.
    February 6, 2012
    322
    05:03 PM
    -but let me prepare you: the BATID is not an unique number, so comparing two project files will probably show a lot of duplicates.
    The Element.UniqueID is, well, unique :-) -across all project files, ever.
    Attached Thumbnails Attached Thumbnails Script for project files comparison?-2018-08-14_1138.png
    June 13, 2011
    Australia
    844
    03:03 AM
    Yes the id the number i am after. Would it just be 2 projects or do you open 1 at a time and extract it?
    February 6, 2012
    322
    05:03 PM
    1 at a time, as far as i'm concerned. I know of Dynamo wizards that can extract info from project files without opening them, but i'm no such wizard :-)
    The startCol and startRow parameters in the ExcelWriteToFile node, will allow you to enter the data in different columns, one for each project.
    I'm curious; why do you need to check the BATID up against each other?
    And did you know you can copy paste several BATID's just by selecting objects and clicking "ID's of selection"?
    November 21, 2012
    London, United Kingdom
    612
    06:03 PM
    You can extract elements from multiple files at once by using a little Python and some nodes
    The python is:
    Code:
    import clr
    clr.AddReference("RevitAPI")
    import Autodesk
    from Autodesk.Revit.DB import *
    OUT = FilteredElementCollector(IN[0]).WhereElementIsNotElementType().ToElements()
    In essence, we are opening up a Revit Project in Headless Mode (With no interface) and querying the model itself for all Elements (Bear in mind - this is EVERYTHING inside the project: Phases, line styles, floor types, revisions ... the lot. If we want to only get families we run a different Filtered Element Collector) in the model. We then simply run a pattern check across them using Set.Difference that tells us what is different inside of each list of elements and we run this check across the Element Ids.
    Attached Thumbnails Attached Thumbnails Script for project files comparison?-revitforumquery_elementids.jpg
    tuekappel, biff and cellophane like this.
  1. Building Coder: Project Identifier and Fuzzy Comparison
    Last Post: December 21st, 2017, 10:15 AM
  2. Replacing TB's across multiple project files.
    By BrianMyers in forum Architecture and General Revit Questions
    Last Post: July 22nd, 2015, 12:59 PM
  3. batch upgrade project files
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: February 8th, 2014, 02:39 AM
  4. Archiving Project Files
    Last Post: April 18th, 2012, 01:13 PM
  5. Looking for the post regarding cad files moving when project is reopened
    By sdbrownaia in forum Architecture and General Revit Questions
    Last Post: April 13th, 2011, 03:30 PM
