Results 1 to 8 of 8
Like Tree11Likes
  • 1 Post By cellophane
  • 1 Post By Mengelmn
  • 5 Post By DaveP
  • 3 Post By johnp
Thread: Creating Views From Level (Using Excel for Naming)
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    07:35 AM
    I'm missing something dumb here - but I can't get my graph to properly create views by level from a list names in excel. I've tried a number of variations of lacing on the Element.SetParameter nodes, as well as List.Cycle with the levels to try and map everything. There are +/-315 views and 9 levels. It generally will create one set of views, either the first set or last set, and the latter keeps throwing an error about the name already existing. Basically it is reading 9 levels & views, then trying to apply the same name over and over and I can't figure out where I broke it
    Attached Thumbnails Attached Thumbnails Creating Views From Level (Using Excel for Naming)-createviews.png
    danbush likes this.
    May 30, 2015
    201
    06:35 AM
    You will need to create all the views first, if you need 300 you will need to create 300 floorplan elements, then set the parameters of these 300 floorplans.
    August 9, 2011
    Louisville, KY
    6,140
    07:35 AM
    I r smrt.
    That did the trick. Thanks
    Attached Thumbnails Attached Thumbnails Creating Views From Level (Using Excel for Naming)-createviews-revised.png
    May 30, 2015
    201
    06:35 AM
    Be aware that depending on how you do this it is possible to create a lot of views very fast, and if run multiple times to create duplicate views (learned the hard way) Solution is to first set up a cross check if any of the views you want to create already exist in the project.
    amoursol likes this.
    August 9, 2011
    Louisville, KY
    6,140
    07:35 AM
    In this case I'm wiping out every plan view I have and recreating them (easier than messing with the various naming schemes) so that won't be an issue. That said - how would you do the cross check?
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    06:35 AM
    Here's my graph for adding a Level and a whole bunch of Views
    It's pretty heavily customized for our plan Types and all the Views we make, but the top section does the basic "Create Floor and Ceiling Plan"
    At some point, I'm going to convert all those ugly Boolean boxes to a nice neat Data Shapes form.
    I've documented all the Packages used. You'll need a few of ours.
    • OrdinalNumbers converts an integer (15) to "FIFTEENTH"
    • SetSheetTitleFromView set the View Title on Sheet
    • SheetInfoFromView figures out the string we use for the Title on Sheet according to our standards
    Attached Files Attached Files
    August 9, 2011
    Louisville, KY
    6,140
    07:35 AM
    Is there a way to set the View Family Type pulling the values from Excel instead of having dozens of ViewFamilyType nodes setting the parameter value? When trying I get an error stating: The parameter's storage type is not a string
    edit: I can collect the types, just not sure how to take the excel sorting and apply the actual type element.
    johnp likes this.
    Member johnp's Avatar
    March 24, 2015
    149
    05:35 AM
    Dictionaries might help
    Attached Thumbnails Attached Thumbnails Creating Views From Level (Using Excel for Naming)-2018-08-01_15-05-40.jpg
  1. Pre-naming section views
    By wwdreamb in forum Architecture and General Revit Questions
    Last Post: July 14th, 2016, 01:55 AM
  2. Creating rooms using an excel file
    By Jorgensen in forum Dynamo BIM
    Last Post: March 30th, 2016, 08:21 AM
  3. Creating a section to a level.
    By Andythebear in forum Architecture and General Revit Questions
    Last Post: March 18th, 2016, 09:45 AM
  4. What Revit Wants: Creating an Excel auto-save backup task
    By luke.johnson in forum Blog Feeds
    Last Post: August 20th, 2013, 06:15 AM
  5. Naming Views
    By domsib in forum MEP - General
    Last Post: March 11th, 2013, 10:29 PM
