Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By cellophane
Thread: Callout boundry and callout leader direction and callout head location?
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,486
    10:02 PM
    is there a way with Dynamo to control the size of a callout boundary? Also, and the leader direction and callout head location be altered with Dynamo?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    01:02 AM
    From what I've found it is only possible through the API: https://forum.dynamobim.com/t/refere...y-curves/14779
    Maybe some of the more Dynamo savvy folks might chime in with a better method?
    elton williams likes this.
    Dave Jones's Avatar
    4,486
    10:02 PM
    thanks for that Chad but unfortunately, Way Over my Head I'm interested in two results, #1 being able to set the callout boundary size and shape for multiple instances, and #2 be able to control the location of the callout head in relation to the callout boundary. The standard location is pointing in the 0 direction. That's OK for my section detail callouts but for plan view callouts I want them all pointing up (90). Sometimes I have lots of them and it's a PITA to have to manually move the callout heads for each individual callout instance. If I can get confirmation that these options can be accomplished somehow with Dynamo, Python, or whatever I'll then pay someone to create the programming.
    10,036
    12:02 AM
    The link Chad posted deals with Reference Other View callouts. Are you talking about those, or Live Callouts?
    Dave Jones's Avatar
    4,486
    10:02 PM
    Other view callouts which I use a lot to refer to drafting views
    Member johnp's Avatar
    March 24, 2015
    148
    11:02 PM
    So, the good news is, you can modify the crop regions with the attached DYN. There is also a GIF of it in action.
    For the location of the elbow and bend of the bubble, I am not sure that is accessible in the API unfortunately. (At least I couldn't find it )
    Hope this at least helps with some of it though! (Note- The python scripts in the file are remixes of stuff in the MEPOver package)
    https://drive.google.com/open?id=1dv...b9T3lBgBIpNG05
    Attached Thumbnails Attached Thumbnails Callout boundry and callout leader direction and callout head location?-20180709-cropregion.gif
    Dave Jones's Avatar
    4,486
    10:02 PM
    Quote Originally Posted by johnp View Post
    thanks John, the shape of the crop region boundary was sort of an offshoot from my real want (question). If you manually move a crop region detail reference bubble to, say 90º, then copy/paste that crop region the bubble returns to 0º most of the time. Sometimes the copy/paste will maintain the orientation of the leader and bubble but most times not and I have no idea why that is. But, I spend a lot of time readjusting detail bubbles and was looking for a method to shortcut the process. Thanks for looking into this for me.
  1. Callout Leader Issues
    By Jason Smith in forum Architecture and General Revit Questions
    Last Post: March 5th, 2018, 04:07 PM
  2. Callout Head Issue - Leader Line not attaching
    By amoroso in forum Architecture - Family Creation
    Last Post: August 13th, 2015, 05:43 PM
  3. Reference a View with a Callout Bubble only and no Callout Boundary?
    By tzframpton in forum Architecture and General Revit Questions
    Last Post: July 2nd, 2013, 05:03 PM
  4. callout head gap - eliminate?
    Last Post: August 16th, 2011, 10:28 PM
  5. Leader attached to callout head
    By Alfienoakes in forum Architecture and General Revit Questions
    Last Post: May 20th, 2011, 03:07 PM
