Results 1 to 6 of 6
Like Tree14Likes
  • 5 Post By johnp
  • 3 Post By amoursol
  • 4 Post By cellophane
  • 2 Post By quyprotk07
Thread: REVIT API or DYNAMO?
    June 6, 2016
    24
    12:17 AM
    Question REVIT API or DYNAMO?
    Hi all!
    I'm using revit structure. And i want to improve performance of my work. But i don't know what i should to choose to start. Learning REVIT API, or DYNAMO?
    Can anyone give me an advise?
    Thanks a lot!
    Member johnp's Avatar
    March 24, 2015
    149
    11:17 AM
    Start learning Dynamo first, and you will find that you need to delve into Revit API more along the way. Since Dynamo works on top of the Revit API, it will enable you to learn the correct way to "think".
    The way I learned is, Dynamo > Python (in Dynamo) > C# (in Dynamo) > Full Revit Addins in C#
    June 6, 2016
    24
    12:17 AM
    Quote Originally Posted by johnp View Post
    Thanks Johnp!
    I will follow your way.
    November 21, 2012
    London, United Kingdom
    612
    06:17 PM
    One thing to add: In terms of progression, Python and C# kind of sit in the same space, but are very different approaches with pro's and con's to both
    Python can be difficult to begin with (But check out my blog post to get started: Diving Deeper - A Beginners Look at Python in Dynamo), but can iterate very very quickly!
    However, most folk prefer C# eventually as you can migrate into Revit add-ons a little easier (There is a lot more tutorial resource available on the web).
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,143
    01:17 PM
    Quote Originally Posted by amoursol View Post
    There is the PyRevit addin that uses Python modules which can speed the jump to add-ons a little.
    June 6, 2016
    24
    12:17 AM
    Thanks all!
    johnp and amoursol like this.
  1. Replies: 0
    Last Post: October 20th, 2017, 01:15 PM
  2. Revit to/from Excel with Dynamo
    By josephpeel in forum Dynamo BIM
    Last Post: December 12th, 2014, 08:01 AM
  3. Replies: 0
    Last Post: November 19th, 2014, 11:45 AM
  4. What Revit Wants: Is Dynamo the new API?
    By luke.johnson in forum Blog Feeds
    Last Post: January 15th, 2014, 03:15 AM
  5. Replies: 0
    Last Post: August 26th, 2013, 07:45 AM
Tags for this Thread
