Results 1 to 7 of 7
Like Tree9Likes
  • 1 Post By johnp
  • 2 Post By cellophane
  • 5 Post By DaveP
  • 1 Post By josephpeel
Thread: Placing Views on Sheets
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    5,999
    08:02 PM
    Stupid question:
    I'm trying to place some dependent views onto sheets. I can collect the views, the sheets, the viewport location from the reference view, and filter everything appropriately, but when I run the graph it only places the first view in the list regardless of what the lacing is set to. If the lacing is set to Longest or Cross Product it will return nulls for everything... I'm assuming it is something dumb that I'm not doing correctly but I can't figure out what.
    The sheets & dependent views all exist in the file already, just want to place them.
    Attached Thumbnails Attached Thumbnails Placing Views on Sheets-placeviews.png
    November 21, 2012
    London, United Kingdom
    612
    02:02 AM
    Are you in 1.3.3 or 2.0? Custom nodes will potentially break between versions.
    August 9, 2011
    Louisville, KY
    5,999
    08:02 PM
    Looks like 1.3.2
    Attached Thumbnails Attached Thumbnails Placing Views on Sheets-dynamoversion.png
    Member johnp's Avatar
    March 24, 2015
    138
    06:02 PM
    Where does "Tool.PlaceViewOnSheets" come from? You might want to see what the insides of that node is doing.
    I also have "Viewport.Create" in Rhythm which places views on sheets.
    amoursol likes this.
    August 9, 2011
    Louisville, KY
    5,999
    08:02 PM
    Tool.PlaceViewOnSheets is from SteamNodes. Inside is a couple of inputs and some Python. Nothing looks funny in terms of only running one sheet at a time, but I'm not very good with python...
    Thanks - I'll check it out!
    edit: The Viewport.Create from Rhythm worked
    amoursol and johnp like this.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,760
    07:02 PM
    Stupid question; even stupider reply:
    I had a similar graph that was driving me nuts for a while.
    It would place the Dependant Views on the Sheets just fine, but it wouldn't place the parent Views.
    Scratched my head about that one for a few days until I realized that, since there wasn't anything ON the parent Views, Revit itself wouldn't place them. Revit won't let you place an empty View on a Sheet. Since the Dependent Views has Scope Boxes and Crop Regions, they had something visible, and thus Revit was fine with placing them.
    Had to adjust the workflow to make sure we model something - or at least place Grids - between creating the Views and placing them on Sheets.
    May 3, 2012
    1,381
    02:02 AM
    Had the same issue when making a load of drafting views on sheets, for details to be filled in later.
    I just put some text with the view name in each view before placing.
    I would actually suggest you dont turn on grids when placing views.. They stick out of the viewport, and the view gets placed by the midpoint of the extents not the midpoint of the viewport. So with grids on the views can end up all a bit off centre.
    Something I also do is put the view placement coordinates in the Title Block. Then you can place a list of views on a load of sheets with different formats, and read the correct position from each title block Type/Size. I guess it would be possible to do the same for legend, detail, section coordinates in the same title blocks and build the whole sheet in one go.
    cganiere likes this.
  1. Browse sheets or views, place or relocate views onto sheets with Ideate SheetManager
    By Rwtaylor_Revit in forum Third party Add-Ins, API and R&D
    Last Post: December 7th, 2017, 11:35 PM
  2. Placing views on sheets
    By Andrew P in forum Dynamo BIM
    Last Post: December 11th, 2016, 07:07 PM
  3. Rotate plan views – not the views on the sheets
    By jh75 in forum Architecture and General Revit Questions
    Last Post: May 30th, 2013, 09:36 AM
  4. Placing imported cad upright in 3D views?
    By basilmir in forum Architecture and General Revit Questions
    Last Post: April 16th, 2013, 07:26 PM
  5. Sheets - Getting Views to fit?
    By domsib in forum Architecture and General Revit Questions
    Last Post: November 22nd, 2012, 10:11 AM
