Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By amoursol
Thread: Dynamo area units
    April 12, 2011
    Chicago, IL
    523
    06:12 AM
    Dynamo area units
    Ok, this seems like it should be a really simple answer, but I'm having a lot of trouble getting it to work properly. I'm trying to create a graph to find rated doors that have glazing and make sure that glazing is not more than the 100 square inches allowed by code. I can get the doors and pull the glazing areas out, but I can't seem to figure out how to input a number as an area to compare the parameter to, or strip the units off the area just to compare numbers to numbers. What am I missing here?
    Thanks in advance...
    May 30, 2015
    201
    06:12 AM
    Dynamo doesn’t make a distinction between “area” vs “length” they are both simple values.
    Share what you have done so far and maybe we can help further.
    April 12, 2011
    Chicago, IL
    523
    06:12 AM
    I got it to work by converting the area to a string, stripping the non-number characters out, and converting it back to a number, but this seems like a really clumsy way to do something that should be simple. When I try to check the area against the number with the > node, it just returns nulls.
    April 12, 2011
    Chicago, IL
    523
    06:12 AM
    I think I just figured out what the problem was. I was using the Parameter.ParameterByName node instead of the Element.GetParameterValueByName. That looks like it will simplify things a lot.
    November 21, 2012
    London, United Kingdom
    612
    12:12 PM
    You could also use Parameter.Value and cut out your middle ground!
    cganiere likes this.
    April 12, 2011
    Chicago, IL
    523
    06:12 AM
    Is this what you're talking about? That seems like an extra step compared to Element.GetParameterValueByName unless I'm using it wrong.
    November 21, 2012
    612
    12:12 PM
    No you're totally right - I personally use the Element.GetParameterValueByName node also! Just saying that in lieu of string conversion you could have done it another way
  1. Fixture Units Updates after updating units in families
    By edwardsdv in forum MEP - General
    Last Post: September 21st, 2017, 09:51 PM
  2. Find the surface area of structural beams using Dynamo BIM!
    By Simply Complex in forum Blog Feeds
    Last Post: December 19th, 2016, 07:16 AM
  3. Replies: 0
    Last Post: September 14th, 2015, 12:15 PM
  4. Area of Curtain System-Dynamo?
    By cliff collins in forum Dynamo BIM
    Last Post: August 20th, 2015, 10:08 AM
  5. Replies: 0
    Last Post: August 1st, 2014, 01:15 AM
