Results 1 to 8 of 8
Like Tree12Likes
  • 1 Post By johnp
  • 2 Post By cellophane
  • 4 Post By johnp
  • 3 Post By johnp
Thread: Rhythm UI.UserMessage node
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    11:32 AM
    I've got some versioning issues.
    I'm still using Dynamo 1.3.2 (need 2016 support)
    I had been on Revit 2018.2 & recently upgraded to Revit 2018.3.1.
    That caused some problems with the version of Rhythm I had installed (2017.11.6)
    So I installed the latest build of Rhythm (2018.6.7)
    Now I'm missing the UI.UserMessage node.
    Was that node deprecated somewhere in the late 6 months?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    12:32 PM
    I think it was at some point - it doesn't show up in the Git https://github.com/sixtysecondrevit/RhythmForDynamo/
    Member johnp's Avatar
    March 24, 2015
    149
    10:32 AM
    Yeah, I dropped that node recently as data-shapes provides better functionality in terms of UI. (removed in this commit, https://github.com/sixtysecondrevit/...91564a92a992b6)
    However, I was thinking of adding it back as a ZeroTouch node because my version used the builtin Revit popups. Would that be appreciated? Also feel free to simply pull the Python from an old version.
    Attached Thumbnails Attached Thumbnails Rhythm UI.UserMessage node-usermessage.png
    cellophane likes this.
    August 9, 2011
    Louisville, KY
    6,140
    12:32 PM
    Quote Originally Posted by johnp View Post
    I liked it for simple messages. I had it in the graph that checked file versions - although everything else in that graph was through Data-Shapes
    johnp and amoursol like this.
    March 24, 2015
    149
    10:32 AM
    Cool will add back as ZeroTouch node.
    March 24, 2015
    149
    10:32 AM
    Here is a quick update on some additions I am working on.
    I thought this would be a good opportunity to actually expand on this functionaility a bit. The second one is a cancellable passthrough.
    Attached Thumbnails Attached Thumbnails Rhythm UI.UserMessage node-20180710-usermessages.gif
    August 9, 2011
    Louisville, KY
    6,140
    12:32 PM
    Loving the passthrough option!
    March 24, 2015
    149
    10:32 AM
    Update published today! Has the helper nodes.
  1. GetSurroundingElements Node Not Working
    By pivoarch in forum Dynamo BIM
    Last Post: October 27th, 2016, 01:52 PM
  2. Re: BVN Node “View.SetUnderlayToNone”
    By Brad Peters in forum Dynamo BIM
    Last Post: October 15th, 2016, 06:22 PM
  3. Dynamic Relaxation node
    By Andrew P in forum Dynamo BIM
    Last Post: October 14th, 2016, 08:58 AM
  4. Node to read totals from schedules.
    By Revitaoist in forum Dynamo BIM
    Last Post: November 20th, 2015, 06:45 AM
  5. Select Model Elements node
    By Ning Zhou in forum Dynamo BIM
    Last Post: July 31st, 2015, 01:34 AM
