Results 1 to 5 of 5
Like Tree7Likes
  • 4 Post By johnp
  • 3 Post By johnp
Thread: How to get double placed objects?
    November 18, 2013
    Germany
    105
    04:40 PM
    Hello Dynos,
    I have a nice small script to get mirrored doors. How can I create in the same way a script to find double placed objects. For example walls.
    And next step should be to erase them. Is there even a topic like this? I think it should not so complicaded, because I have also the warnings and the IDs…
    I hope I get some advise
    Thank you!
    Kind Regards
    Andreas
    Attached Files Attached Files
    Member johnp's Avatar
    March 24, 2015
    149
    10:40 AM
    Using the performance adviser rules is a great way to fix this.
    Attached Thumbnails Attached Thumbnails How to get double placed objects?-2018-05-29_9-56-48.png
    amoursol, Nevon, Ning Zhou and 1 others like this.
    July 20, 2011
    850
    09:40 AM
    anyone know how to change or stop workflow? for instance, if no overlapping walls then list is empty and warning(s) will be generated instead of just stopping remaining nodes from running, i saw similar post but no good solution @ https://forum.dynamobim.com/t/how-to...top-it/9472/14
    Attached Thumbnails Attached Thumbnails How to get double placed objects?-capture.png
    November 21, 2012
    London, United Kingdom
    612
    05:40 PM
    Hello Ning,
    There is no way to currently stop execution of a workflow that I know about out-of-the-box. There is a possibility of looking into this with Extensions (Where you could stipulate that if a null/empty list passes through a node - cancel execution on that branch).
    The problem is that a node will try and execute always - and that the Element.Id node will always fail if it doesn't pick up on a valid Id.
    March 24, 2015
    149
    10:40 AM
    Quote Originally Posted by amoursol View Post
    There is no way to currently stop execution of a workflow that I know about out-of-the-box. .
    This is doable in Python though! (Using designtech's progress bar approach too). https://designtech.io/dynamo/dynamo-progress-bar/
    Attached Thumbnails Attached Thumbnails How to get double placed objects?-20180613-checkfamiliesforcadimports2.gif
    amoursol, Mengelmn and josephpeel like this.
  1. double post
    By Darius in forum Out There
    Last Post: January 5th, 2017, 08:32 PM
  2. double channel
    By maidafa in forum Structure - Family Creation
    Last Post: July 29th, 2016, 09:40 AM
  3. Double Take
    By MPwuzhere in forum Rendering and Gallery
    Last Post: November 5th, 2014, 07:22 AM
  4. Double Ls in words
    By cellophane in forum Forum Suggestions and Feedback
    Last Post: June 12th, 2012, 11:32 PM
