Results 1 to 7 of 7
Like Tree6Likes
  • 6 Post By DaveP
Thread: View Scales report differently
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,984
    06:45 AM
    Not sure if I should ask this here, or on the Dynamo forum, but it seems like more of a Revit question.
    I've got a graph that Aligns Views on Sheets.
    One of the first things it does is to filter down the Views so it only looks a Views with the same Scale as the one you're matching.
    It's been working fine for a while, but now I've got a project where some of the View are reporting a Scale of 1/8" = 1'-0", and others are reporting the Scale as 96.
    We (at least those of us in the US) would recognize those as the same, but Dynamo sees it as a string, so they're different.
    How and Why did some View get set up using the inches=feet style and some as just the scale number?
    And: any simple way to correlate the two?
    January 10, 2011
    St Paul, MN
    2,984
    06:45 AM
    There's a Core node named "Number From Feet and Inches", but it doesn't accept input.
    It only lets you type in a hard-coded value.
    Also looked at Springs.Fraction2Feet, but that's either not working (possibly because of leading blanks) or not able to pass thru the value if it's already just a number (96)
    January 10, 2011
    St Paul, MN
    2,984
    06:45 AM
    Found it! (I love answering my own questions )
    The "View Scale" parameter returns differently "united" values - some 1/8" = 1'-0", some 96, some just empty.
    Instead, I found the "Scale Value" parameter, which always returns the value as a number.
    That's not all, though.
    The parameter name is not just "Scale Value"
    The parameter name is "Scale Value 1:"
    Yes, there are spaces in between the Value and the 1. Four spaces to be exact. That took some trial and error
    AND there IS a colon at the end.
    May 30, 2015
    201
    06:45 AM
    Where are you pulling it from specifically, I’ve seen the difference but not in the same list as you show.
    May 30, 2015
    201
    06:45 AM
    Quote Originally Posted by Mengelmn View Post
    Note to self - read full thread
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,143
    07:45 AM
Name:	View Scales.PNG
    I'm curious about the fact that some come in as a fraction and some as a decimal.. I ran a quick test here and everything came in as a decimal value (96) no matter how I collect the value. I collected it using both Element.GetParameterValueByName and View.Scale (clockwork) and everything looked normal
    January 10, 2011
    St Paul, MN
    2,984
    06:45 AM
    The only thing I found in common was that the ones that showed feet and inches used View Templates, and the ones that had just a number did not have the Scale included in the VT.
    Didn't do a comprehensive comparison, but it looked that way at first glance.
  1. Text acts differently
    By glkirk in forum Architecture and General Revit Questions
    Last Post: May 9th, 2018, 10:42 AM
  2. Graphic Scales
    By MrBIMtastic in forum Architecture and General Revit Questions
    Last Post: December 16th, 2015, 06:52 PM
  3. Hide at scales
    By anjali in forum Architecture and General Revit Questions
    Last Post: January 23rd, 2014, 01:08 PM
  4. Scales
    Last Post: January 22nd, 2013, 01:06 PM
  5. Naming every instance of a group differently
    By edmund in forum Architecture and General Revit Questions
    Last Post: May 4th, 2012, 09:27 AM
