Results 1 to 3 of 3
Thread: Revit 2017 Dynamo nodes
    July 20, 2011
    850
    09:40 PM
    my Revit 2017 Dynamo nodes are kind of dead, i have to use Revit 2018 to do node editing and run it in Revit 2017, but since one Dynamo script needs to select model element manually, now i'm stuck.
    anyone experienced similar issue? how to fix it?
    November 21, 2012
    London, United Kingdom
    612
    05:40 AM
    Not personally experienced it, no. I would reach out to the Dynamo team directly for this one!
    July 20, 2011
    850
    09:40 PM
    thanks Sol, Jacob from "https://forum.dynamobim.com/t/revit-2017-dynamo-nodes/21790/7" kindly provided the possibilities, yet to figure out exactly what happens, for the time being, i'll edit script in Revit 2018, and run it in Revit 2017 project(s) if needed
  1. Replies: 3
    Last Post: October 18th, 2017, 09:09 AM
  2. Rhino to Revit via Spring Nodes/Dynamo Cut Hatch Issue
    By thompsonburry in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: August 27th, 2016, 03:42 PM
  3. revit 2017 & dynamo
    By Darius in forum Dynamo BIM
    Last Post: May 11th, 2016, 08:32 PM
  4. Replies: 0
    Last Post: November 23rd, 2015, 04:45 AM
  5. What Revit Wants: Keeping Custom Dynamo Nodes in Sync
    By luke.johnson in forum Blog Feeds
    Last Post: June 27th, 2015, 03:15 PM
