Results 1 to 9 of 9
Like Tree3Likes
  • 1 Post By kraftwerk
Thread: Apply view template on view
    August 29, 2015
    95
    07:46 AM
    Hello!
    I need a node that apply view template on views, do you know a package that has that node?
    Best regards Engineer
    Junior Member kraftwerk's Avatar
    November 1, 2012
    St. Louis, MO
    40
    02:46 AM
    Take a look at archi-lab's package, SetViewTemplate. Be sure to check version as it was just upgraded to Dynamo 2.0 last week.
    August 29, 2015
    95
    07:46 AM
    Thank you! I installed dynamo 2.0 unfortunately i get following error:
    I have tried to uninstall all dynamo versions and then only install 2.0, but i still got same error. Does someone now how to solve the problem?
    Attached Thumbnails Attached Thumbnails Apply view template on view-error.png   Apply view template on view-error2.png
    November 1, 2012
    St. Louis, MO
    40
    02:46 AM
    Next helpful bit of advice, stay away from Dynamo 2.0. Seriously, it "failed to meet expectations as a stable software platform" would be the really nice way to state that.
    Recommend going back to download a 1.3.2 or 1.3.1 which were both very stable. I have been working on 2018.1 and Dynamo 2.0 and it has been nothing short of infuriating to say the least. If you are new with Dynamo, most of the packages have not been 'improved' to work well with Dynamo 2.0, so most packages are still working the same way in 1.3.2.
    Wait a couple of months before promoting to Dynamo 2.0. I know its always exciting to upgrade to the latest and greatest, but save yourself 10 hours of work just for it to not work and not upgrade.
    Also, here is a post of issues on Dynamo's github of something similar to what you are experiencing. You may have PnID installed? https://github.com/DynamoDS/Dynamo/issues/8768
    Happy Tuesday.
    josephpeel likes this.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,124
    03:46 AM
    I found these site, but I don't know how much help they will be since both are fairly old at this point:
    https://forum.dynamobim.com/t/how-to...exception/5791
    https://www.revit.news/2016/07/resol...ion-in-dynamo/
    May 3, 2012
    1,401
    09:46 AM
    Thanks. I was considering upgrading..
    November 1, 2012
    St. Louis, MO
    40
    02:46 AM
    I will say that I have worked through a lot of the issues that were surrounding 2.0. The instability came from a Custom Node library that I maintain. How certain things were handled in pre-2.0 to 2.0 caused that instability. For most users, it should be stable.
    One thing I would say is that upgrading graphs from 1.3 to 2.0 causes them to not function properly back in 1.3. Keep a separate set of graphs in a 1.3 backup folder location, just in case if you try to open in 2.0 and they crash, you can find out the issue in 1.3.
    amoursol likes this.
    August 29, 2015
    95
    07:46 AM
    Quote Originally Posted by kraftwerk View Post
    I want to Apply template properties, not set view template. Where can i find a node that do that?
    Attached Thumbnails Attached Thumbnails Apply view template on view-apply.png
    November 1, 2012
    St. Louis, MO
    40
    02:46 AM
    A View Template is just a View to Revit. So, you set the View Templates as a View and then the views that have that View Template applied just inherit the properties of the view.
    What all of that means is that you can set the view properties of the View (i.e. the View Template), which then get inherited to all of your other views. See the screenshot below.
    Attached Thumbnails Attached Thumbnails Apply view template on view-2019-02-12_slarcs0321_0000.png
  1. Apply a filter within a view template to make building sections invisible
    By katewood1989 in forum Architecture and General Revit Questions
    Last Post: March 21st, 2018, 06:27 AM
  2. Apply vew template to ne view
    By Marco79 in forum Nederlands forum
    Last Post: April 25th, 2017, 06:22 AM
  3. Revit OpEd: Apply versus APPLY and View Templates
    Last Post: June 21st, 2013, 09:15 PM
  4. Replies: 0
    Last Post: March 7th, 2013, 07:15 AM
  5. Revit OpEd: Apply View Template to all Views
    Last Post: May 16th, 2012, 03:15 PM
