Results 1 to 8 of 8
Thread: change wall location line to wall centerline
    November 18, 2013
    Germany
    103
    04:52 AM
    Hello Dynos,
    I would like to reset the Location line to wall centerline - all walls How?
    I found something in the forum(.dyn) but it doesn`t work. It seems to be not a "regular" Parameter. Need I access to the API via Python?
    Is there an easer way?
    My first aim would be just to list this parameter visible(watch)
    I would be glad to have some advise, info, screenshots, solutions,...
    KR
    Andreas
    Attached Thumbnails Attached Thumbnails change wall location line to wall centerline-wall-location_line.jpg
    Attached Files Attached Files
    Gold Coast
    2,602
    02:52 PM
    Maybe I don't understand the full extent of what you're trying to achieve, but couldn't you just select all the walls in a 3D view and change their values all at once in the properties browser?
    May 30, 2015
    200
    11:52 PM
    Quote Originally Posted by andreasdraxl View Post
    Hello Dynos,
    KR
    Andreas
    The reason nothing is updating is most likely related to that you are imputing an “empty” list into your “set parameter”. Essentially you are telling Revit to set the parameter of Zero elements.
    I use forms of the process often so to set the location of multiple types at once. Example set all exterior walls to “face of core”
    Gold Coast
    2,602
    02:52 PM
    Quote Originally Posted by Mengelmn View Post
    Yes, this script is showing all the selected walls as already set to 0: Wall Centreline, with a few blanks - maybe curtain walls or MIP geometry?
    May 30, 2015
    200
    11:52 PM
    Can you clarify what you are trying to achieve? Are you wanting to set ALL walls to centerline? Or a subset?
    If you clarify your end goal more help may be possible
    November 18, 2013
    Germany
    103
    04:52 AM
    I want that all walls have one location line! thats all. Thank for your attention... thats my wish
    Attached Thumbnails Attached Thumbnails change wall location line to wall centerline-alle_waende.jpg
    May 30, 2015
    200
    11:52 PM
    Try this simple process. If you want to set All walls, then only ones you need to filter out is those that do not have the “location line” parameter. - Alternatively you can run this with out the filter, you will get an error, but those that have it will be set.
    November 18, 2013
    Germany
    103
    04:52 AM
    Thank you very much, that was it! It works and is realy simple
  1. Wall location line
    By Ecotech Kid in forum Architecture and General Revit Questions
    Last Post: May 17th, 2017, 08:15 AM
  2. Stacked wall - location line issues?
    By kmgates in forum Architecture and General Revit Questions
    Last Post: December 12th, 2016, 02:55 PM
  3. Revit OpEd: Copy Monitor Wall Location Line Selection
    Last Post: November 9th, 2015, 06:15 PM
  4. Replies: 0
    Last Post: August 13th, 2015, 03:15 PM
  5. David Light: Be Consistent – Wall Location Line:
    By David Light Blog in forum Blog Feeds
    Last Post: July 9th, 2013, 05:45 PM
