Results 1 to 8 of 8
Like Tree5Likes
  • 1 Post By duende123
  • 2 Post By duende123
  • 1 Post By amoursol
Thread: Transfer levels from one slab to another
    Member duende123's Avatar
    November 20, 2015
    186
    04:23 AM
    I have 2 floors with edited shape
    I want transfer the levels from B to A
    I used SlabShape.Points to get the X & Y coordinates of the vertices of A
    How can I get the Z values corresponding to the B floor in order to modify the floor A?
    Attached Thumbnails Attached Thumbnails Transfer levels from one slab to another-z00.jpg
    November 21, 2012
    London, United Kingdom
    612
    09:23 AM
    Hello Lewis,
    Have a go at this and see if it does what you wish.
    Attached Thumbnails Attached Thumbnails Transfer levels from one slab to another-revitforumquery_slabshape.jpg
    November 20, 2015
    186
    04:23 AM
    I completed a little more with your information but
    that way all the points take the same level Z
    I need to project every point of the orange floor on the green floor that has variable height
    I need something like this:
    but it seems that this is not how this node is used
    Attached Thumbnails Attached Thumbnails Transfer levels from one slab to another-z01.jpg
    josephpeel likes this.
    November 21, 2012
    612
    09:23 AM
    Can you please tell me what package the SlabShape.Points node comes from? I can have a look at your workflow then.
    Also, are you looking to simply shift a floor up to another level (host) ? Or are you looking to retain the level host and shift the points upwards based on another level?
    November 20, 2015
    186
    04:23 AM
    From Landform nodes...
    https://dynamonodes.com/2016/01/29/l...dex/#more-1110
    Both floor are the same host level and the same Height offset from level.
    The height of the vertices of the floor A has been modified with "Modify sub elements"
    I pretend that dynamo modifies the vertices of the B floor so that they have the same height according to the position where they are.
    I add Element.Geometry and then Point.Project don't make error but the output is null.
    Attached Thumbnails Attached Thumbnails Transfer levels from one slab to another-z03.jpg
    November 20, 2015
    186
    04:23 AM
    Finally it worked.
    MatchFloor01.dyn
    Attached Thumbnails Attached Thumbnails Transfer levels from one slab to another-z05.jpg
    josephpeel and amoursol like this.
    November 21, 2012
    612
    09:23 AM
    Hello Lewis,
    Have a go with the following solution:
    Attached Thumbnails Attached Thumbnails Transfer levels from one slab to another-revitforumquery_slab_shape.png
    duende123 likes this.
    November 20, 2015
    186
    04:23 AM
    Thanks Amursol ...
    your solution is different than mine, so I will study it to learn new ways.
    amoursol likes this.
  1. Topography point levels not matching survey levels??? help!!!???
    By craiglarkinmsj in forum Architecture and General Revit Questions
    Last Post: June 2nd, 2015, 02:25 PM
  2. elevations and levels won't transfer
    By elton williams in forum Architecture and General Revit Questions
    Last Post: June 24th, 2013, 02:08 PM
  3. Hiding Levels from Links, keep host levels - best practice?
    By tzframpton in forum Architecture and General Revit Questions
    Last Post: January 14th, 2013, 05:37 PM
  4. Replies: 0
    Last Post: July 31st, 2012, 11:45 PM
  5. Replies: 0
    Last Post: March 16th, 2012, 04:45 AM
