Results 1 to 5 of 5
Thread: Two inputs that looks the same, behave differently when plugged in
    Moderator gaby424's Avatar
    December 11, 2010
    911
    01:49 PM
    Hello,
    Long time no see
    Short problem story:
    I make some testing with a script from dynamo forum (credits to Daniel_Woodcock1).
    -The creator generated manually the input list for the views to be placed on sheets (a code block where he is writing the name of the views)
    -I tried to generate the same list of views via a filter method using a keyword and the watch node show me the same result (the same view list).
    -The bad thing is that when I pass my input in the place on sheet node, the application freeze. His input works
    What do I miss?
    See picture or test your self with the revit and dynamo files attached (check run to freeze the app with my input that is already plugged in or make it work by connecting his input, see in the picture the red dashed line ) )
    Long story:
    I`m working to agregate a series of already solved dynamo scripts around the web so I can generate a window schedule with pictures (you know, like usually we do in Europe, Archicad style)
    In the process I`ve been stuck with that beautiful file (credits to Daniel_Woodcock1) that seems to do what I need, in one of the steps.
    Here is the original file:
    https://forum.dynamobim.com/t/place-...nates/12883/39
    and here is the explained the structure of the needed inputs:
    https://forum.dynamobim.com/t/place-...nates/12883/44
    I`ve also posted this problem there, but nobody seems to analize my post
    Needing your help
    Thank you
    Attached Thumbnails Attached Thumbnails Two inputs that looks the same, behave differently when plugged in-tets.png
    Attached Files Attached Files
    December 11, 2010
    911
    01:49 PM
    to run the file see picture
    Attached Thumbnails Attached Thumbnails Two inputs that looks the same, behave differently when plugged in-run.png
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    07:49 AM
    have you tried collecting your schedule(s) in a different way?
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    319
    01:49 PM
    Look at the difference between what you are feeding (that doesn't work) and what the working example is feeding.
    There's a difference in layers of nesting in the list. You are feeding a list, containing a list, containing your view(s). He is feeding a list, containing views. His is 1 level simpler that yours. The first test I would build is flattening your list, so you also just have a list containing views.
    December 11, 2010
    911
    01:49 PM
    to Bjorn_K
    He also have 2 levels. Zoom in a little in the picture and read the L1 L2 L3 text on bouth nodes in the left bottom corner, or open the file and you will see we have the same thing
    to cellophane
    what way are you having in mind?
  1. Replies: 0
    Last Post: December 21st, 2017, 11:15 AM
  2. CPU comparison, your inputs appreciated
    By revitogreniyorum in forum Hardware and Infrastructure
    Last Post: July 10th, 2015, 01:28 AM
  3. Looking for answers, Cable families that behave like flex duct.
    By cadehand in forum Architecture - Family Creation
    Last Post: March 12th, 2015, 03:58 PM
  4. Basic cube with variable inputs
    By r3dd0t in forum Architecture - Family Creation
    Last Post: August 6th, 2014, 02:43 PM
  5. Keynote tag behave different
    By gaby424 in forum Architecture and General Revit Questions
    Last Post: March 17th, 2011, 10:47 PM
