Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Like Tree19Likes
Thread: Dynamo Player
    December 21, 2010
    C.LONDON
    4,353
    01:45 PM
    Dynamo Player
    I've read both of these:
    https://knowledge.autodesk.com/suppo...563E2-htm.html
    https://knowledge.autodesk.com/suppo...CE47E-htm.html
    up-and-down, round-and-round, and still for the life of me can't coax Dynamo Player into offering up Inputs with even a simple script like the one attached...
    One worry/concern is that my Player looks nothing like the one in the screenshots to even begin with....? Is it cos' I is stuck in (Revit) 2017?
    I'm running an up-to-date Dynamo.
    Attached Files Attached Files
    July 7, 2011
    Rotterdam, Holland
    1,166
    02:45 PM
    I think you need to input the data before you run the script.
    I don't think there is a popup asking for input
    December 21, 2010
    C.LONDON
    4,353
    01:45 PM
    Quote Originally Posted by Robin Deurloo View Post
    it's this that I can't seem to invoke:
    Attached Thumbnails Attached Thumbnails Dynamo Player-guid-a4cacff4-2044-468b-bc16-daac60cdfb99.png
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    08:45 AM
    The ability to use the IsInput in Dynamo Player is a 2018 feature.
    Attached Thumbnails Attached Thumbnails Dynamo Player-dynamoplayer2018.png   Dynamo Player-dynamoplayer2017.png
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    313
    02:45 PM
    If you are stuck in 2017 for the foreseeable future, don't forget you can also use the Data Shapes package to build your own inputs/dialogs. (Combine with the player for easy of use in a wider office scenario)
    josephpeel and amoursol like this.
    December 21, 2010
    C.LONDON
    4,353
    01:45 PM
    Aha! Cheers Chad!
    Might be able to hold out on 2018 entirely if 2019 (?) comes quick....
    Quote Originally Posted by Bjorn_K View Post
    I've seen Data Shapes get mentioned a lot but haven't latched into what's it about and have yet to take a look - my work's generally focussed elsewhere these days so I don't get to play enough.
    Gold Coast
    2,602
    10:45 PM
    Do it, its well worth it imo. Data shapes nodes are slightly more complex to string together (but not a lot), the dialogues popup when you need them and users dont need to go digging in dynamo player, which i feel is still underdeveloped.
    amoursol likes this.
    April 8, 2011
    313
    02:45 PM
    For the people who have not seen this before:
    Munkholm likes this.
    December 21, 2010
    C.LONDON
    4,353
    01:45 PM
    Oooooo. I've seen people showing off with things that look like that - and mistook them for custom api'addin thingys - not Dynamo-born.
    Bjorn, when you first mentioned Data Shapes above, your post made it sound like being in 2017 was advantageous - are Data Shapes not long for the world?
    August 9, 2011
    Louisville, KY
    6,104
    08:45 AM
    Data Shapes is awesome. Even with the IsInput in Dynamo Player, having the UI for making selections is (IMO) better than relying on the inputs in the player.
  1. Alphabetize the Scripts in the Player?
    By safoulkes in forum Dynamo BIM
    Last Post: January 29th, 2018, 07:34 PM
  2. Replies: 0
    Last Post: October 20th, 2017, 01:15 PM
  3. Replies: 0
    Last Post: November 19th, 2014, 12:45 PM
  4. Replies: 0
    Last Post: August 26th, 2013, 07:45 AM
  5. Replies: 0
    Last Post: February 29th, 2012, 12:15 AM
