Results 1 to 2 of 2
Thread: Polar coordinates to x/y/z coordinaters
    Member uaifestival's Avatar
    May 28, 2014
    Tokyo
    95
    07:03 PM
    Question Polar coordinates to x/y/z coordinaters
    Hello folks,
    Has anybody tried to transform with Dynamo cartesian coordinates (I do not know how you called X/Y/Z in U.S) into polar coordinates (which is the table that Revit can read) to draw property lines within Revit?
    May 28, 2014
    Tokyo
    95
    07:03 PM
    Question A first try into transform coordinates
    I gave it a try but I encountered the" Null value cannot be cast to Int32."
    I am using Revit 2017 with Dynamo 1.2....
    First I have to move the origin to something real n the file since the survey was pointing at zero somewhere...else.
    Ideally teh graph will terminate with Revit read an excel file to create a property line.
    Attached Thumbnails Attached Thumbnails Polar coordinates to x/y/z coordinaters-transformcoordinateintopolarcoordinates.png
    Attached Files Attached Files
  1. Site Setup - Acquire Coordinates vs. Specify Coordinates at a Point
    By Mel in forum Architecture and General Revit Questions
    Last Post: September 7th, 2016, 11:03 PM
  2. transpose coordinates?
    By ronvs in forum Dynamo BIM
    Last Post: April 22nd, 2016, 03:28 PM
  3. Coordinates and overlay
    By domsib in forum Architecture and General Revit Questions
    Last Post: June 21st, 2013, 07:43 PM
  4. Marking x, y & z coordinates
    By DanDr in forum Architecture and General Revit Questions
    Last Post: October 12th, 2012, 10:36 AM
  5. Spot coordinates
    By assem in forum Architecture and General Revit Questions
    Last Post: July 17th, 2012, 01:06 PM
Tags for this Thread
