Results 1 to 8 of 8
Thread: Using If node to Override rooms color in view
    Junior Member Aida Siala's Avatar
    October 25, 2017
    27
    06:07 PM
    Hello,
    I used IF node to override rooms color in view according to the condition:
    If the list is empty, override rooms color in red
    If the list is not empty, override rooms color in green.
    But, there is a mistake somewhere because the script override them in red in both cases
    Attached Thumbnails Attached Thumbnails Using If node to Override rooms color in view-cp.jpg
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    313
    07:07 PM
    You want to override the Rooms in a color, the color depends on the condition. Then have the IF node only confirm the color for you, and after the IF node override the Rooms.
    The way you have it set up now, Dynamo is overriding the Rooms before your data arrives at your if node.
    It can work like this:
    December 21, 2010
    C.LONDON
    4,353
    06:07 PM
    One thread's enough Aida!
    But I'll let you off this time as I can't presently remember how to merge...
    https://www.revitforum.org/dynamo-bi...olor-view.html
    October 25, 2017
    27
    06:07 PM
    Yes, that is what I need Bjorn!
    Thank you
    October 25, 2017
    27
    06:07 PM
    Thanks Snowyweston
    October 25, 2017
    27
    06:07 PM
    Hi Bjorn,
    the node Element Override color in view does not always works
    Attached Thumbnails Attached Thumbnails Using If node to Override rooms color in view-2018-03-14.png
    May 3, 2012
    1,396
    07:07 PM
    Your IF is grey, which means not complete. Connect something to False, even if it is just 'null;'
    October 25, 2017
    27
    06:07 PM
    I get it,
    Thanks josephpeel!
  1. using IF node to override rooms color in view
    By Aida Siala in forum Dynamo BIM
    Last Post: March 8th, 2018, 02:47 PM
  2. Replies: 0
    Last Post: June 1st, 2017, 07:15 AM
  3. Color Fill - Only Fills a few rooms not all: how I can fix to color all rooms?
    By revit_user in forum Architecture and General Revit Questions
    Last Post: November 30th, 2016, 08:01 PM
  4. Override Linked model wall color. Is it possible?
    By Hilife in forum Architecture and General Revit Questions
    Last Post: March 21st, 2013, 05:27 PM
  5. Override walls with solid color and pattern by filter
    By KimArndt in forum Architecture and General Revit Questions
    Last Post: September 16th, 2011, 01:26 PM
