Results 1 to 1 of 1
Like Tree2Likes
  • 2 Post By Thomas__Mahon
Thread: Bimorph Nodes V2.2 Adds Holistic Support for Linked Element Clash Detection
    October 14, 2017
    London
    7
    04:04 AM
    Bimorph Nodes V2.2 Adds Holistic Support For Linked Element Clash Detection With New Link-Element Nodes
    Dear Dynamo Community
    I am delighted to announce the release of BimorphNodes v2.2, which is now available for download via the Dynamo Package Manager.
    BimorphNodes v2.2 introduces the new LinkElement class nodes to Dynamo which are purpose-built for retrieving elements from linked Revit models. While this functionality has existed for some time in a number of other packages, what makes LinkElements unique are the range of additional properties and features they implement that solve a major limitation in the Revit API (and therefore Dynamo) concerning the location of linked elements within their host file.
    The other significant update in v2.2, also related to this issue, is the addition of holistic support for linked element clash detection using any of the Bimorph Element and BoundingBox nodes. LinkElements serve a vital role in enabling this functionality, resulting in a range of nodes that are no longer impeded by the problems that arise from limitations in the Revit API.
    BimorphNodes v2.2 overview:
    • New LinkElement class nodes for rapid interop with elements from linked Revit models
    • Element.IntersectsElement, Element.IntersectsSolid, BoundingBox.GetElementsInside and BoundingBox.GetElementsIntersect nodes now provide holistic support for linked elements
    • Clash detection codebase micro-optimised, resulting in +15% performance increase
    • CAD.CurveFromCADLayers refactored with improved support for view-specific CAD links
    • Curve.RemoveDuplicates refactored resulting in +80% performance increase
    • Built on the Revit 2017 API (Revit 2015 no longer supported)
    • Efficiency enhancements and general stability improvements
    New LinkElement Class Nodes
    The new LinkElement nodes include a range of methods and properties for retrieving and interacting with Elements from a linked Revit model (a Link Instance). What makes LinkElements unique are the way they locate the linked element in the host file. This is significant as the Revit API has a limitation which restricts linked elements to their external files origin-to-origin location, regardless of any transformations made to them in the host file. LinkElements have been purpose-built to solve this limitation by performing operations, such as geometry extraction, at the linked elements host location.
    To create LinkElement instances, use the LinkElement.OfCategory node:
    Properties and metadata attached to the LinkElement instance can be accessed using the LinkElement property nodes. The Solids, Faces, Location and BoundingBox nodes return the respective geometry at its host location by default:
    There are also property nodes to access its associated Link Instance id, total transform and the embedded Dynamo Revit Element:
    LinkElements Solve the Revit API Linked Element Transform Limitation
    The linked element transform limitation manifests only in the Revit API context, which subsequently exposes a number of BimorphNodes to the problem. As mentioned, this limitation causes linked elements to default to their external files
    origin-to-origin position, regardless of any transformations made to their Link Instance in the host document. The Revit projects most at risk are those where transformations have been applied to the Link Instance for coordination purposes, which is likely if Shared Coordinates are in use or if linked models have been manually moved to align with the main building model.
    The problem is most pronounced when calling Revit API methods on a linked element where its relative location in the host file is required to yield a result. For example, the Revit API ElementQuickFilter and ElementSlowFilter class methods – which are used for clash detection in the BimorphNodes BoundingBox and Element nodes – produce erroneous results if element A vs B includes any linked elements which have been transformed. This is especially confusing to users since any linked Revit models which are moved to visually align with other links or live elements in the host file, are positioned back at their respective
    origin-to-origin locations in the API context (which the users cant see), causing the clash results to fail unexpectedly.
    The following example illustrates the problem, showing the position of bounding boxes created in the API context from linked wall elements while its Link Instance is transformed. One would expect the bounding boxes to be drawn where the walls are positioned in the host model, but the Revit API limits them to the links
    origin-to-origin location:
    <span style="font-family: verdana">https://youtu.be/3ru-o6vGHk4
    LinkElements on the other-hand solve the problem by handling linked elements at their host location (where you see it in Revit), and this new functionality forms the basis for enabling holistic linked element support in the Bimorph BoundingBox and Element nodes:
    <span style="font-family: verdana">https://youtu.be/1-0ee1hSFWE
    Optimized for Bimorph Nodes Element and BoundingBox Nodes
    LinkElements are optimized for use with BimorphNodes Element and BoundingBox nodes to maintain their ultra-efficient performance and provide holistic support for linked elements, regardless of any transformations made to their associated Link Instance. However, to achieve this, a dependency on LinkElements has been implemented which restricts linked element inputs to this type only. Subsequently, any custom code or package which collects linked elements (SpringNodes, Archi-lab, SteamNodes, etc) are no longer supported. The decision to drop support was a consequence of:
    • There being no direct way to identify a linked elements Link Instance through the API, which is critical as it stores the total transform (coordinate system) needed to locate the element at its host location. The Link Instance can be obtained indirectly by accessing the elements Document property, but this simple technique crippled performance, causing speed-of-execution to drop by more than 250%
    • Moreover, even if this approach was adopted, it’s flawed as the available data provides no means to reliably identify a Link Instance if it has been linked multiple times in the same file
    Settling for compromised functionality that would have prohibited unlimited support of Link Instances (in fact, it would have limited each link to just 1 per document) with crippled performance, was unacceptable, and this led to the development of the LinkElement class and the decision to make it exclusive.
    The LinkElement class therefore plays a vital role in enabling the new linked element support in the Bimorph Element and BoundingBox nodes.
    LinkElements Inherit Dynamo’s Element Class
    To maximise functionality, LinkElements inherit from Dynamo’s Revit.Elements.Element class, meaning instances are compatible with all of Dynamo’s Element nodes and any other nodes that accept Elements as inputs.
    There are some limitations with certain nodes in Dynamo’s Revit library that will not recognize LinkElements. For example, LinkElement Room’s are not compatible with the OOTB Room nodes, such as Room.Number, due to the inheritance hierarchy. To resolve such issues, use the LinkElement.Element node to extract the wrapped Revit element (i.e. the Dynamo Revit Element).
    One drawback of extracting the Element is the loss of properties provided by the LinkElement. It means that any operations, such as geometry extraction, revert back to the linked elements origin-to-origin location. To manually resolve this issue, use the OOTB Geometry.Translate node and input the corresponding LinkElements TotalTransform as the ‘context coordinate system’. The ‘from coordinate system’ should always be the global Identity:
    Holistic Support for Linked-Element Clash Detection
    The Element.IntersectsElement, Element.IntersectsSolid, BoundingBox.GetElementsInside and BoundingBox.GetElementsIntersecthave been updated with a new clash detective algorithm which enables holistic support for linked elements even if their Link Instances have been transformed or translated. It means that the limitation imposed on linked elements by the Revit API, which before the update impeded their functionality, is now fully resolved.
    To provide this support the nodes depend on the new LinkElement class and leverage its properties to locate linked elements at their host locations. By utilising LinkElements, the nodes can be used to develop unique and highly versatile workflows that range from supporting linked elements from an unlimited number of Link Instances (ideal for large-scale schemes and master plans where multiple Link Instances are common), to linked element vs linked element clash detection, even if the elements derive from multiple Link Instances with different
    origin-to-origin locations (a problem which has no direct solution in the Revit API).
    The nodes also implement a smart logic-tree which is designed to execute only the subroutines that are relevant to the conditions of the intersection test being computed. The logic tree is central to minimising any performance overheads that arise from the new infrastructure, resulting in near-negligible compromises to speed-of-execution.
    Summary of new features:
    • Resolves the Revit API limitation imposed on linked elements
    • Supports elements from an unlimited number of Link Instances
    • LinkElement vs LinkElement clash detection fully supported
    • Smart logic-tree minimises performance overheads of new functionality
    • Micro-optimised
    Surpasses Revit’s Interference Check Tool
    The functionality built into the new clash detective algorithm enables BimorphNodes to surpass the functionality offered by Revit’s built-in Interference Check (IC) tool. For example:
    • IC limits users to 1 Link Instance per clash test, whereas BimorpNodes support an unlimited number of Link Instances
    • IC does not support linked element vs linked element clash detection, nor does it allow clash tests to be performed between elements from the same Link Instance; BimorphNodes fully supports these types of clash tests (ideal for projects with many Link Instances)
    • IC requires at least 1 live element in the active model before it can be used; BimorphNodes has no such restriction
    In terms of performance, clash detection using BimorphNodes is between 2-3x faster than the IC tool, however its not possible to conduct any meaningful performance analysis as the IC functions differently and requires additional time to render the UI clash report dialog.
    How it Works
    Providing the Element and BoundingBox nodes with holistic support for linked elements has not resulted in any changes to their inputs or outputs as all the updates have occurred internally. Therefore, using LinkElements with these nodes is no different to using Elements; simply collect the required linked elements using the LinkElement.OfCategory node, then provide the resultant LinkElement instances as inputs.
    The following graph shows how to utilise LinkElements with the Element.IntersectsElement node to perform multi-category linked element clash detection, without being impeded by the Revit API limitations:
    Utilising LinkElements with the BoundingBox.GetElementsIntersect node:
    Are There Performance Impacts?
    To enable holistic support for linked elements the Element and BoundingBox codebase has grown significantly. The new infrastructure includes subroutines that execute based on the conditions of the elements input (ordinary Element, non-LinkElement, LinkElement or tranformed LinkElement) and include all the logic to resolve the linked element transform limitation.
    With more subroutines to execute, it stands to reason that impacts on performance would be inevitable. However, a fundamental objective for BimorphNodes v2.2 was to add the new functionality without undermining the ultra-efficient performance achieved in v2.1. Hence, we implemented a range of measures to minimize potential performance impacts, which included:
    • Creation of the LinkElement class, optimised for use with BimorphNodes
    • Micro-optimisation of the codebase
    • Building BimorphNodes on the newer Revit 2017 API
    The result? Between a 15-90% performance increase compared to BimorphNodes v2.1.
    The following table shows the performance improvements using the Element.IntersectsElement node. For the purposes of comparison, the Walls vs Ducts clash test conducted when BimorphNodes v2.1 was released is used as the benchmark:
    Performance Comparison Matrix
    The table below shows the performance comparisons of the various clash tests between live Elements vs LinkElements controlled by the logic tree. The test conditions use the same Walls vs Ducts model used in the ‘Performance Impacts’ benchmark above:
    Computation times shown in seconds. Walls (2,300) vs Ducts (2,160). Total Possible Clash Tests: 4,968,000.
    Transformed LinkElements are moved, rotated and mirrored from their origin-to-origin location
    Tested on: Windows 10, Revit 2018.2, Dynamo 1.3.2 and HP ZBook Intel i7-4710MQ 2.5GHz, 16GB DDR Memory, 256GB SSD
    Validation Sampling
    To support the transition to LinkElements, BimorphNodes BoundingBox and Element nodes include new exception handling to validate the list of elements input by the user. While this provides useful feedback if an invalid linked element is found, it reintroduces the performance impacts that led to the development of the LinkElement class in the first place (as the validation procedure must access each elements Document property to check if it is linked). To mitigate these impacts but still provide the advantages of element validation, a method of ‘validation sampling’ has been implemented.
    Validation sampling selects a range of elements from the list at every interval using the equation: d / (5 + (0.01 * d)) where d = the count of items in the input list. Sampled elements are tested to verify if they are linked and where true, if they are instances of the LinkElement class. If any elements are linked but not LinkElements, the following exception is thrown:
    Note that as a selection of elements are evaluated, there is potential non-valid linked elements can pass through the validation test if they are between the selection interval. However, the risks are negligible as the user would need to input a heterogeneous list interspersed with only a few invalid linked elements for this to occur. To eliminate the risk completely, always use LinkElements when your workflow requires them.
    Mitigating ‘Dereferencing a Non-Pointer’ Exceptions
    There is known bug in Dynamo which throws a ‘dereferencing a non-pointer’ exception whenever a list of objects which contains either null or an empty list at index 0 (the start of the list) is input into any Query (property) node.
    While most workflows are unlikely to be affected, it requires special mention since the Element.Intersects nodes are designed to output clash results via a 2D list (list of lists), where empty sub-lists indicate no clashes. Due to this behavior, there is a higher probability that index 0 will be empty, making these nodes more susceptible to the bug.
    As the Dynamo dev team have stated the bug is unlikely to be fixed by Dynamo v2.0, a simple workaround can be used in the interim by cleaning the list of empty sub-lists before passing it into any Query nodes using the OOTB List.IsEmpty (set to @L2 lacing) and List.FilterByBoolMask.
    The following example shows a method for maintaining the data-structure output by the Element.Intersects nodes after cleaning the list:
    New Updates
    There have also been a range of updates made to the nodes listed below. To learn more about what has changed and see the full range of nodes in v2.2, visit the main article covering the release of BimorphNodes V2.2 here.
    • CAD.CurvesFromCADLayers Adds View-Specific CAD Instance Support
    • Curve.RemoveDuplicates Refactored and 80% More Efficient
    • LineStyle.Create Breaking Changes
    • Element.IsElementSupported Improved Results
    • Element.IsCategorySupported Depreciated
    Get Updates
    Check out the BimorphNodes content pages and YouTube channel for video user guides and downloadable example graphs:
    BimorphNodes Dictionary
    YouTube Channel
    We’ve also recently moved the BimorphNodes dictionary to our new domain, bimorph.com. Links for the old .co.uk domain automatically redirect, but we recommend updating any bookmarks and referring links to point to the new domain.
    cellophane and PolynineStudio like this.
  1. Replies: 3
    Last Post: October 18th, 2017, 09:09 AM
  2. Clash Detection as a Service
    By chompi0n in forum MEP - General
    Last Post: September 25th, 2014, 04:48 PM
  3. Navis Clash Detection?
    Last Post: December 15th, 2013, 08:45 PM
  4. Which is better for Clash Detection in mep - BIM or Revit?
    By bimservices in forum Architecture and General Revit Questions
    Last Post: June 26th, 2012, 07:00 PM
  5. What Are You Using For Clash Detection?
    By renogreen in forum Coordination Tools
    Last Post: May 14th, 2012, 06:29 PM
Tags for this Thread
