Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By snowyweston
Thread: using IF node to override rooms color in view
    Junior Member Aida Siala's Avatar
    October 25, 2017
    27
    05:34 PM
    Hello,
    I want to override rooms color through IF condition :
    If the list contains "true"
    => the first room of the rooms list will be colored in green
    Apparently, I did not know how to use the IF node!
    Can some one help me, please.
    Attached Thumbnails Attached Thumbnails using IF node to override rooms color in view-forum.jpg
    December 21, 2010
    C.LONDON
    4,353
    05:34 PM
    1. (noting I'm not all that Dynamo savvy) - rather than use the IF node, use the boolean mask node.
    2. (being more Revit-minded) I'd be inclined to suggest, for permanence, you inject the calculated True/False values into an SP so that you can exploit Revit's color schemes pre-setup in a dedicated (plan) view.
    GMcDowellJr likes this.
    October 25, 2017
    27
    05:34 PM
    I tried with List.FilterByBoolMask but it does not work because I have two different lists each consists of one element.
    - List 1: contains the room ID that I am checking.
    - List 2: contains "True" or "False".
    I want to have the room ID when list 2 contains "True".
    Attached Thumbnails Attached Thumbnails using IF node to override rooms color in view-forum-3.jpg
    Member uaifestival's Avatar
    May 28, 2014
    Tokyo
    95
    01:34 AM
    it seems you are feeding the List.Filterbyboolmask with the wrong lace to me. That node should read the same amount of data (list) that you feed into the mask through previous nodes (such in your image list.Containsitem/== /.... and what is there before it cannot be read through yout picture. You can upload a larger picture by simply exporting the graph as image from Dynamo menu. File>exportworkspacesasimage.
    November 21, 2012
    London, United Kingdom
    612
    05:34 PM
    Try using the ScopeIf node instead of the If - it should function more like you expect!
    February 2, 2011
    Montreal/Paris
    830
    11:34 AM
    OUt of your == use a IndexOf and use True
    Then from the original list use ItemAtIndex
    This will give you a list of rooms that you can feed in the color
    But the FilterBYBooleanMask should work if you are only looking for True
    October 25, 2017
    27
    05:34 PM
  1. Curtain Wall System Panel Color Override
    By Warp Drive in forum Architecture and General Revit Questions
    Last Post: July 24th, 2017, 09:00 PM
  2. Replies: 0
    Last Post: June 1st, 2017, 07:15 AM
  3. Color Fill - Only Fills a few rooms not all: how I can fix to color all rooms?
    By revit_user in forum Architecture and General Revit Questions
    Last Post: November 30th, 2016, 08:01 PM
  4. Override Linked model wall color. Is it possible?
    By Hilife in forum Architecture and General Revit Questions
    Last Post: March 21st, 2013, 05:27 PM
  5. Override walls with solid color and pattern by filter
    By KimArndt in forum Architecture and General Revit Questions
    Last Post: September 16th, 2011, 01:26 PM
