Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By amoursol
  • 1 Post By Gerta75
Thread: Pulling parameters from a linked file
    Junior Member Gerta75's Avatar
    May 11, 2015
    Denver, CO
    17
    09:17 AM
    I am trying to use Dynamo to pull parameter info from a linked Mechanical model and use it to populate the corresponding piece of equipment in my Electrical model.
    Please see the active discussion here:
    https://www.revitforum.org/mep-gener...cal-model.html
    I'm hoping a Dynamo guru can provide me with some insight. Perhaps even a better method of approaching the task.
    Thanks,
    Jake
    November 21, 2012
    London, United Kingdom
    612
    05:17 PM
    Hello Gerta,
    Could you please provide a sample project? I'm not an MEP engineer and this would provide me with a base to get it working! You're very close to getting it working, but there are some improvements I can suggest. I can whip them up if you get me the model
    johnp likes this.
    May 11, 2015
    Denver, CO
    17
    09:17 AM
    Thank you! Here is a dropbox folder with a test project set up in Revit '17. Let me knoiw if you need anything else.
    https://www.dropbox.com/sh/ec6k073au...9m64UDQDa?dl=0
    November 21, 2012
    612
    05:17 PM
    Quote Originally Posted by Gerta75 View Post
    Hello Gerta,
    I'm not quite sure I'm setting up the file correctly - please tell me if this is right...
    For some reason, I'm not getting the results you are.
    I have opened the 'A' model (Architectural?), and linked in the 'MP' and 'E' models. I tried by Shared Coordinates but one failed - so I manually moved them into place.
    I'm still getting no intersections sadly.
    The premise of what you need to do is, however, pair up your files. You could use a dictionary for this which would make it easier and simpler rather than using GetItemAtIndex and so on.
    Any thoughts on the set-up? I get this result so far:
    Attached Thumbnails Attached Thumbnails Pulling parameters from a linked file-revitforumquery_3d-set-up.jpg   Pulling parameters from a linked file-revitforumquery_links.jpg   Pulling parameters from a linked file-revitforumquery_dynamoemptylists.jpg
    May 11, 2015
    Denver, CO
    17
    09:17 AM
    Sorry, some explanation would have been nice on my end.
    You’ll be working out of the E model. The A and MP models should be linked already, but you’ll have to repath them. If you navigate to the floor plan sheet? You’ll see a note in red. The copy/monitor progress is finished, so it should just be a matter of running the dyn script and getting the correct results.
    Again, I really appreciate your assistance with this.
    November 21, 2012
    612
    05:17 PM
    Ok cool! Quick question ... Are these the results you're expecting?
    In essence, Linked file has 10 families (EF-1, FCU-1 etc).
    Live 'E' Model has 6 families (All 'Motor')
    Geometry.DoesIntersect
    picks up multiple 'trues' for some - and none for others.
    Attached Thumbnails Attached Thumbnails Pulling parameters from a linked file-revitforumquery_progress.jpg
    May 11, 2015
    Denver, CO
    17
    09:17 AM
    Yes, during the copy/monitor, I brought in only the 6 pieces of MECH equipment that I am interested in (see EDS below). The "P-1" is considered plumbing equipment and I decided not to bring that in for this experiment.
    Attached Thumbnails Attached Thumbnails Pulling parameters from a linked file-eds.jpg
    amoursol likes this.
    November 21, 2012
    612
    05:17 PM
    Apologies Gertz, I had hoped to look at this before I left. I'm currently in New Zealand at a stag-do / wedding so don't have time to play for a while.
    Hopefully someone else can help! If not, i'll have time in a week or two to look at this.
  1. linked file to another linked file view and control problems
    By shotgun_banjo in forum Architecture and General Revit Questions
    Last Post: May 4th, 2016, 12:47 AM
  2. Sheet Index discipline attribute not pulling from linked files
    By jchandler in forum Architecture and General Revit Questions
    Last Post: March 25th, 2016, 01:15 PM
  3. Linked CAD file in a linked Revit file
    By maciejwypych in forum Architecture and General Revit Questions
    Last Post: November 13th, 2014, 01:33 AM
  4. Linked CAD in a linked Revit file
    By aykhan9 in forum MEP - General
    Last Post: June 22nd, 2014, 09:57 PM
  5. Architects file linked into Interiors File
    By Patrick in forum Architecture and General Revit Questions
    Last Post: July 2nd, 2012, 09:25 PM
Tags for this Thread
