Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Like Tree15Likes
Thread: Wall profile
    April 12, 2011
    Chicago, IL
    523
    11:30 AM
    Wall profile
    I'm starting to look at setting up some procedures for model auditing as part of a QC plan in my office, and I've found a few useful graphs out there already. One of the things I'm seeing a lot of in certain models is an overuse of editing wall profiles, so I was wondering if there's any way Dynamo can tell if a wall has an edited profile so I can generate some reports. So far all I've seen in related searches are people trying to modify the profile, which I don't really care about. I just want to know how many walls have edits.
    Thanks in advance for any help.
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    322
    04:30 PM
    Just throwing out a random idea: how about using the reset profile command for all walls, and doing a volume comparison between before and after? All the walls with edit profile will have changed their area or volume.
    After that just roll back the undo's or close without save.
    Sendt fra min ONEPLUS A5000 med Tapatalk
    April 12, 2011
    Chicago, IL
    523
    11:30 AM
    Seems like that would need to be manually done in revit in between dynamo exporting to excel and then doing some math after the fact. I'm hoping to find something more automatic.
    November 21, 2012
    London, United Kingdom
    612
    05:30 PM
    Quote Originally Posted by chris.macko View Post
    This is a little more automatic!! First list is sweeps, and the second list is reveals​.
    Dynamo Graph:
    In Revit to test:
    Script:
    Code:
    # Authored by Sol Amour (2018)
    # @solamour amoursol@gmail.com
    # Importing the Common Language Runtime module
    import clr
    # Adding RevitServices module to access the Document Manager to query Elements from the Document
    clr.AddReference("RevitServices")
    import RevitServices
    from RevitServices.Persistence import DocumentManager
    doc = DocumentManager.Instance.CurrentDBDocument
    # Adding the Revit API module
    clr.AddReference("RevitAPI")
    from Autodesk.Revit.DB import *
    # Using a custom flatten function (Lambda)
    flatten = lambda l: [item for sublist in l for item in sublist]
    # Running two Collectors, one for Sweeps and one for Reveals, discounting their Type families and casting to Elements
    collSweeps = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Cornices).WhereElementIsNotElementType().ToElements()
    collReveals = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Reveals).WhereElementIsNotElementType().ToElements()
    # Running our custom flatten function over a List Comprehension that gets the Host Id of each Sweep adn Reveal
    swpIds = flatten([ s.GetHostIds() for s in collSweeps ])
    revIds = flatten([ r.GetHostIds() for r in collReveals ])
    # Generating empty lists to populate later
    sweepHosts,revealHosts = [],[]
    # Running a for loop to get the Host Elements of Sweeps from the Revit Document by Id
    for s in swpIds:
        sweepHosts.append(doc.GetElement(s))
    # Running a for loop to get the Host Elements of Reveals from the Revit Document by Id
    for r in revIds:
        revealHosts.append(doc.GetElement(r))
    # Outputting both of our Host elements in separate lists: Sweeps for the first, Reveals for the second
    OUT = sweepHosts,revealHosts
    Enjoy!
    Attached Thumbnails Attached Thumbnails Wall profile-revitforumquery_01.jpg   Wall profile-revitforumquery_02.jpg
    chris.macko likes this.
    April 12, 2011
    Chicago, IL
    523
    11:30 AM
    I figured a solution might require Python, which a this point is still way beyond me. Thanks for posting that! Is there any way to get that to report walls that are using the "Edit Profile" function? That's what I'm really after right now, but sweeps and reveals are also good to get a handle on.
    amoursol likes this.
    November 21, 2012
    612
    05:30 PM
    This may be of use to you Chris as the API doesn't appear to have a solution:
    https://forum.dynamobim.com/t/filter...rofile/18149/2
    April 12, 2011
    Chicago, IL
    523
    11:30 AM
    Perfect! I'll play around with that for a while and see what I can come up with. Thanks again for the tip.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    12:30 PM
    Quote Originally Posted by amoursol View Post
    How long should that take to run? I created a test file from a blank template, added 3 walls, attached one to a shed roof, modified one profile and left one alone and it just sat and ran until I killed Revit (admittedly only a minute or two before I killed it)
    April 12, 2011
    Chicago, IL
    523
    11:30 AM
    I just did a test file with 2 walls and it ran pretty quick, but I tried a different file with some more complex edits and it seemed like it locked up. I also plugged some true values into the inputs which maybe I shouldn't have.
    April 12, 2011
    Chicago, IL
    523
    11:30 AM
    I think I got it working like I want. There's just a weird issue that I think might be a bug in the Springs collector node. If I move some of the walls at certain angles, all the outputs change to null, so nothing gets reported at all. If I move the wall back it behaves as expected.
    amoursol and cellophane like this.
  1. Wrapping A Profile On A Wall
    By JD003 in forum Architecture and General Revit Questions
    Last Post: May 2nd, 2015, 05:14 PM
  2. Replies: 4
    Last Post: March 14th, 2013, 02:31 AM
  3. Wall Sweep does not following the wall profile
    By Shefypattambi in forum Architecture and General Revit Questions
    Last Post: May 3rd, 2012, 11:14 AM
  4. Wall profile edit - where's the profile outline?
    By DDenton in forum Architecture and General Revit Questions
    Last Post: August 8th, 2011, 08:48 PM
  5. Wall profile
    By theshell07 in forum Architecture and General Revit Questions
    Last Post: May 10th, 2011, 07:33 PM
