Results 1 to 3 of 3
Like Tree2Likes
  • 2 Post By josephpeel
Thread: Select all elements of System Family
    August 29, 2015
    95
    08:38 PM
    Hello!
    Is there a way to select all elements of system family? It is easy to select all elements of family type by Family Types-node and All elements of Family Type-node but I cant find my cable tray family in the Family Type-node, is that because it is a system family?
    Best regards Engineer
    May 3, 2012
    1,401
    10:38 PM
    You can do it with
    Element Types -> Cable Tray -> All elements of Type
    or Category -> Cable tray -> All Elements of Category
    Then if you want only a specific type filter the results with Type.Name = XXXX
    Attached Thumbnails Attached Thumbnails Select all elements of System Family-get-cable-tray.jpg
    cellophane and amoursol like this.
    August 29, 2015
    95
    08:38 PM
    Quote Originally Posted by josephpeel View Post
    You can do it with
    Thank you! It solved my problem.
  1. If I have hidden a lot of single elements other than manual select and reveal, is the
    By rickyandmortystimemachine in forum Architecture and General Revit Questions
    Last Post: December 8th, 2017, 07:22 PM
  2. Select all connected elements
    By Rune in forum Dynamo BIM
    Last Post: August 1st, 2016, 03:15 PM
  3. Select or view elements by host
    By gru3d in forum Architecture and General Revit Questions
    Last Post: March 28th, 2016, 02:42 AM
  4. Select Model Elements node
    By Ning Zhou in forum Dynamo BIM
    Last Post: July 31st, 2015, 01:34 AM
  5. Draw order- select multiple elements
    By JCM in forum Architecture and General Revit Questions
    Last Post: December 30th, 2010, 05:56 AM
