Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Like Tree3Likes
Thread: Excel to Dynamo
    June 25, 2014
    6
    02:53 AM
    Excel to Dynamo
    Hi:
    I am attempting to replicate the basic process for reading an Excel spread sheet into Dynamo.
    I have placed the same nodes as shown by Nathan Miller in his video
    Dynamo and Excel - Parsing Excel Data with Dynamo.
    Both Excel nodes give the same error message "... operation failed".
    The File Path node returns the correct path, However the File From Path node returns the File Path and not the File Name.
    This seems to be a recurring problem. I checked similar error reports - my File Path contains no spaces and no accented characters. I installed Office 365 yesterday, so I have the latest version of Excel. I am running Revit 2018 and Dynamo 1.3.1.1736. Help with this problem would be much appreciated.
    Regards
    FrankYYZ
    July 20, 2011
    850
    12:53 AM
    readAsStrings default is false so you have to input true
    June 25, 2014
    6
    02:53 AM
    Quote Originally Posted by Ning Zhou View Post
    Thank you for you comment. But setting R
    eadAsString to true does not solve my problem. The error starts as soon as I connect FileFromPath to ExcelGetFileInfo
    The second error occurs when I connect String to SheetName
    Attached Thumbnails Attached Thumbnails Excel to Dynamo-excel-dynamo-3.png   Excel to Dynamo-excel-dynamo-2.png
    July 20, 2011
    850
    12:53 AM
    I have no problem running it, perhaps you can close Dynamo and open/run again, also close Excel if it's already opened
    amoursol likes this.
    February 2, 2011
    Montreal/Paris
    830
    02:53 AM
    Can you post the error message? (little tooltip on top of the node)
    June 25, 2014
    6
    02:53 AM
    Thanks for responding. You can see the error message in the above image. The error message is the same for both nodes. As I asked above, should the File.FromPath node output just the File name? In the image above it outputs the full path
    November 21, 2012
    London, United Kingdom
    612
    08:53 AM
    Quote Originally Posted by Frankyyz View Post
    Sometimes the Excel file being open can be fickle. As Ning Zhou suggested, have you closed Excel for this?
    cganiere likes this.
    February 2, 2011
    Montreal/Paris
    830
    02:53 AM
    What Excel version and x86 or x64?
    June 25, 2014
    6
    02:53 AM
    Quote Originally Posted by DanielHurtubise View Post
    My computer tells me: "System Type x64-based PC". I installed Office 365 this month. I assume I am using the x64 version of Excel.
    THX
    June 25, 2014
    6
    02:53 AM
    Quote Originally Posted by amoursol View Post
    I get the same error when Excel is closed or open
    THX
  1. Replies: 1
    Last Post: August 25th, 2017, 10:25 PM
  2. Dynamo Placeholder Sheets from Excel
    By theintern in forum Dynamo BIM
    Last Post: June 29th, 2016, 07:12 PM
  3. Revit to/from Excel with Dynamo
    By josephpeel in forum Dynamo BIM
    Last Post: December 12th, 2014, 08:01 AM
  4. Revit to/from Excel with Dynamo
    By josephpeel in forum MEP - General
    Last Post: October 13th, 2014, 04:26 PM
  5. BIM Troublemaker: Practical Dynamo - Excel Linking
    By BIM Troublemaker in forum Blog Feeds
    Last Post: September 3rd, 2014, 03:45 AM
Tags for this Thread
