Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Like Tree2Likes
Thread: NWC export in views
    August 29, 2015
    87
    05:58 PM
    NWC export in views
    Hello!
    Can someone help me to export some views to NWC with Dynamo? I have found a node that export active view to NWC, but then I can only export one view. I have tried to modify the python script in "Export Active View (NWC)" but i did not make it.
    Best regards Engineer
    May 3, 2012
    1,396
    06:58 PM
    Does the script have a 'View' input, and if so can you input a list of views?
    Most nodes will take a single item or a list if you give them the right inputs.
    August 29, 2015
    87
    05:58 PM
    Quote Originally Posted by josephpeel View Post
    No it dont, that is the problem. I tried to change the script so it had a view as input, but i did not make it. I guess it is easy if you have done some Revit-scripting, the only thing i want to do is to change from exporting active view, to exporting "input-view". Maybe you can take a look at the code.
    Here is the script:
    import clr
    clr.AddReference('ProtoGeometry')
    from Autodesk.DesignScript.Geometry import *
    # Import ToDSType(bool) extension method
    clr.AddReference("RevitNodes")
    import Revit
    clr.ImportExtensions(Revit.Elements)
    # Import geometry conversion extension methods
    clr.ImportExtensions(Revit.GeometryConversion)
    # Import DocumentManager and TransactionManager
    clr.AddReference("RevitServices")
    import RevitServices
    from RevitServices.Persistence import DocumentManager
    from RevitServices.Transactions import TransactionManager
    from System.Collections.Generic import *
    # Import RevitAPI
    clr.AddReference("RevitAPI")
    import Autodesk
    from Autodesk.Revit.DB import *
    import System
    import math
    doc = DocumentManager.Instance.CurrentDBDocument
    uiapp = DocumentManager.Instance.CurrentUIApplication
    app = uiapp.Application
    uidoc=DocumentManager.Instance.CurrentUIApplicatio n.ActiveUIDocument
    coll = FilteredElementCollector(doc).OfClass(ProjectLocat ion)
    output = []
    path = IN[0]
    name = IN[1]
    #path = Autodesk.Revit.DB.FilePath(pathName)
    Options = Autodesk.Revit.DB.NavisworksExportOptions()
    Options.ExportScope = NavisworksExportScope.View
    Options.ViewId = uidoc.ActiveView.Id
    doc.Export(path,name , Options)
    TransactionManager.Instance.EnsureInTransaction(do c)
    TransactionManager.Instance.TransactionTaskDone()
    doc.Regenerate()
    #OUT = dir(Autodesk.Revit.DB.NavisworksExportOptions.Expo rtScope)
    OUT = 0
    November 21, 2012
    London, United Kingdom
    612
    05:58 PM
    Kia ora Engineer,
    Try the following (Will only work for a single View at present):
    Code:
    import clr
    import Autodesk
    def tolist(item):
        if hasattr(item, "__iter__"): return item
        else: return [item]
    _path = IN[0]
    _name = IN[1]
    _view = UnwrapElement(IN[2])
    outputList = []
    t = TransactionGroup(doc, "Exporting Navisworks Views")
    t.Start()
    for _v in tolist(_view):
        _options = Autodesk.Revit.DB.NavisworksExportOptions()
        _options.ExportScope = NavisworksExportScope.View
        _options.ViewId = _v.Id
        exp = doc.Export(_path, _name , _options)
        outputList.append("Success")
    t.Commit()
    OUT = outputList[0]
    August 29, 2015
    87
    05:58 PM
    Thank you amoursol, it works with one view. But how do i do if i want to export more than one view? I tried to copy the python block and put in different name and views to different python-blocks, but then i got error. "Transaction group cannot be started during an active transaction".
    amoursol likes this.
    November 21, 2012
    612
    05:58 PM
    It's fickle to be honest... I tried getting it working for multiples but to no avail yet. It may need to wrap up multiples into sub-transactions. I can have a play later in the week
    10,035
    11:58 AM
    Quote Originally Posted by amoursol View Post
    Just buy the CTC batch suite. It does this (and much more) and is only a couple hundred dollars. You've probably burned through that just in man hours trying to get the script to run.
    Aaron Maller
    Director
    Parallax Team, Inc.
    December 21, 2010
    Phoenix, AZ
    2,556
    09:58 AM
    Well yeah, but not as much fun!
    November 21, 2012
    612
    05:58 PM
    I simply play with this stuff to learn man!
    September 6, 2015
    London
    1
    07:58 PM
    Aaron, there is definitely a place for hardwired addins, if only for the consistent, ‘canned’ result. Dynamo has a great place but still some library of code/node bits short. I may not know where to save the code blocks so I can quickly assemble larger bits together. I have a number of suites, and don’t use the whole suite because another one does it better.
  1. "views are too large to export"
    Last Post: November 20th, 2017, 01:27 AM
  2. Replies: 1
    Last Post: November 4th, 2017, 04:09 PM
  3. Revit Export to IFC - Cant export to global coords?
    By BigIdiot in forum Structure - Interoperability
    Last Post: January 21st, 2016, 06:36 AM
  4. Replies: 0
    Last Post: January 4th, 2015, 12:45 AM
  5. Replies: 0
    Last Post: November 17th, 2014, 01:15 PM
