Results 1 to 2 of 2
Thread: Setting Revit Parameter by "Phase Created"
    August 23, 2012
    3
    06:41 AM
    I am very new to Dynamo. This is my first kick at the can and I am trying to use dynamo to eliminate some user inputs in our structural projects. I have a custom parameter "Tag Prefix" attached to multiple categories, including structural framing, and our structural framing tag references the "Tag Prefix""Type Name" to give us a tag that reads (N)W12x26. What I am trying to accomplish is to set the "Tag Prefix" parameter based on the "Phase Created". I have attached my first try. Obviously I have something wrong since it only sets (E) to all structural framing.
    Attached Thumbnails Attached Thumbnails Setting Revit Parameter by "Phase Created"-phase-based-tag-prefix.png   Setting Revit Parameter by "Phase Created"-phase-based-tag-prefix.png
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    08:41 AM
    Doesn't look like your attachment made it.
    Without seeing the graph, it sounds like a lacing issue. What's a List | The Dynamo Primer
    note: Thread closed as a duplicate
  1. Setting Revit Parameter by "Phase Created"
    By bteskey in forum Dynamo BIM
    Last Post: January 29th, 2018, 03:26 PM
  2. Replies: 4
    Last Post: June 7th, 2016, 01:32 PM
  3. Changing Phase from "New Construction" to "Existing"
    By joshea191 in forum Architecture and General Revit Questions
    Last Post: May 13th, 2014, 12:23 PM
  4. Error Message: "None of the created elements are visible in Floor Plan"
    By efficiencydesign in forum Architecture and General Revit Questions
    Last Post: March 8th, 2014, 08:05 AM
  5. Shared parameter for "phase" in sheet titleblock?
    By boriskam1991 in forum Architecture and General Revit Questions
    Last Post: December 20th, 2012, 10:28 PM
