Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Like Tree1Likes
Thread: rename importinstance (type)
    July 20, 2011
    850
    09:11 PM
    previously (2015?) Dynamo have node to rename importinstance (type), for instance, Element.Type, Element.SetName, etc
    now what i can think or find is Element.SetParameterByName, but i cannot set "Type" parameter (because its storage type is not string), or "Name" parameter (because it's read-only parameter)
    is it because OOTB Element.SetParameterByName is only for instance parameter?
    January 22, 2018
    1
    04:11 AM
    I look forward to Appling this theory.
    November 21, 2012
    London, United Kingdom
    612
    05:11 AM
    Hello Ning,
    You can't rename the Import Instance - as the name is derived from the actual DWG name, unless I'm mistaken.
    July 20, 2011
    850
    09:11 PM
    see uploaded JPG for your info, happy new year Sol!
    Attached Thumbnails Attached Thumbnails rename importinstance (type)-capture.png
    November 21, 2012
    612
    05:11 AM
    Try Clockwork's Element.SetName node?
    July 20, 2011
    850
    09:11 PM
    thanks Sol, you're right, can only rename type, in fact, i try to create 3D rooms w/o all non-sense names, guess i may have to create (GM) families to host these guys, what do you think?
    November 21, 2012
    612
    05:11 AM
    Yeah, sadly I think this is one of those cases where the API is locked down compared to what buttons are available in Revit itself.
    Nesting into a Generic Model would indeed be one approach. Or depending on what you need - you could make a dictionary?
    July 20, 2011
    850
    09:11 PM
    what do you mean of "make a dictionary?"
    in fact, i just want to get rid of all those non-sense "category" names when for instance selecting/filtering in Revit project
    November 21, 2012
    612
    05:11 AM
    Hello Ning,
    With Dictionaries you can associate a key to a value. In your case, you can call your non-sense names of Rooms a proper name - and then simply refer to the object via a dictionary call on the key.
    Concept shown below:
    What you are doing with a Dictionary is creating a Key : Value pairing, where you can use that key to get the value. Values can be objects, strings, numbers - anything! Key has to be unique, but values can be the same.
    Attached Thumbnails Attached Thumbnails rename importinstance (type)-dictionary.png
    josephpeel likes this.
    July 20, 2011
    850
    09:11 PM
    cool, i used dictionary quite a lot in c# coding for Revit API, but never used (or figured out how to) in Dynamo, for this particular case, don't know yet how to apply your idea, the problem is all that non-sense names are actually Revit "category" not "subcategory", even after rename its type, see JPGs (before and after renaming)
    Attached Thumbnails Attached Thumbnails rename importinstance (type)-capture-3.png   rename importinstance (type)-capture-2.png   rename importinstance (type)-capture_1.png   rename importinstance (type)-capture-4.png
  1. Rename family type
    By wave in forum Architecture - Family Creation
    Last Post: September 4th, 2016, 12:04 PM
  2. How to rename Drafting View 'Type' in API
    By RipJust in forum Third party Add-Ins, API and R&D
    Last Post: July 9th, 2015, 12:23 PM
  3. ImportInstance.ByGeometries DynamoBIM Node explained
    By Simply Complex in forum Blog Feeds
    Last Post: February 15th, 2015, 05:16 PM
  4. Rename shared parameter
    By kowen1208 in forum Architecture and General Revit Questions
    Last Post: February 24th, 2014, 04:56 PM
  5. 2010 : Get link of ImportInstance
    By pierrenavarra in forum Third party Add-Ins, API and R&D
    Last Post: November 2nd, 2011, 03:43 PM
