Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By andreasdraxl
Thread: Where is the Problem? in the script
    November 18, 2013
    Germany
    108
    12:42 PM
    Hello! Dynos,
    I have a beautiful script, and it runs on my Dynamo! on my Laptop! But when I run the script, on a other Laptop it is not running!
    I get this error:
    Which package is missing?:
    Thats my tree:
    I use 1.3.0 Dynamo I have no update possibility - because I am not Admin!
    Please help me, I am glad about any advise...
    Kind Regards
    Andreas
    Attached Thumbnails Attached Thumbnails Where is the Problem? in the script-missing_link.jpg   Where is the Problem? in the script-packages.jpg   Where is the Problem? in the script-benutzerdefiniert.jpg   Where is the Problem? in the script-error-tree.jpg
    November 21, 2012
    London, United Kingdom
    612
    01:42 PM
    It appears you have an older version of the Custom Package installed (0.1.5) instead of the one the graph is expecting (0.6.3.0). Because all nodes have a GUID associated with them, even if they are the 'same', it will break due to versioning.
    Try downloading the latest version of 'Turn Into list.dyf'
    November 18, 2013
    Germany
    108
    12:42 PM
    That means lates Version clockwork!
    November 21, 2012
    612
    01:42 PM
    In this case, Andrea's (Clockwork author) would have used another packages Custom Node. You simply need to download that individual package - or alternatively, you can switch out the node on your own system (But then the graph isn't transferable to other machines).
    November 18, 2013
    Germany
    108
    12:42 PM
    the note is from archilap even than it doesn`t work
    November 18, 2013
    Germany
    108
    12:42 PM
    It worked right now... thank you!
    amoursol likes this.
  1. Need help debugging a script
    By dtp81390 in forum Dynamo BIM
    Last Post: April 28th, 2017, 04:00 PM
  2. Not Sure Why Script Isnt Working
    By Bdcoll in forum Dynamo BIM
    Last Post: January 21st, 2016, 12:36 PM
  3. Add-in or script for auto dimensions?
    By josephpeel in forum Third party Add-Ins, API and R&D
    Last Post: July 28th, 2014, 07:39 AM
  4. Run script at every save?
    By doni49 in forum Third party Add-Ins, API and R&D
    Last Post: October 4th, 2013, 08:17 PM
  5. Script Error on Startup
    By Mel in forum Architecture and General Revit Questions
    Last Post: October 29th, 2012, 09:02 PM
