Results 1 to 9 of 9
Like Tree7Likes
  • 1 Post By irneb
  • 3 Post By irneb
  • 2 Post By irneb
  • 1 Post By cellophane
Thread: Isolate by Type Parameter
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    403
    05:27 AM
    I'm looking to isolate elements in a 3d based on their type parameter, but I can't seem to even get access to the Type parameter data using the Element.GetParameterValueByName node, am i missing something easy? (and yes they do all have Type Marks set)
    Attached Thumbnails Attached Thumbnails Isolate by Type Parameter-isolatebytype.png
    October 11, 2012
    St. Louis
    403
    05:27 AM
    The Get Type Parameter in the Archilab-Grimshaw package seemed to do the trick
    Attached Thumbnails Attached Thumbnails Isolate by Type Parameter-isolatebytype2.png
    Member irneb's Avatar
    April 25, 2013
    Jo'burg SA
    350
    02:27 PM
    The issue is that a type parameter isn't stored inside the element, rather inside the element's type. It "does" make sense if you think about it.
    So to get to the type parameter you first need to get to the type:
    Attached Thumbnails Attached Thumbnails Isolate by Type Parameter-params.png
    amoursol likes this.
    April 25, 2013
    Jo'burg SA
    350
    02:27 PM
    As example, you could make your own custom node to handle both cases as one:
    Then it's a single node in your script, no matter if you're looking for an instance parameter or a type parameter.
    Attached Thumbnails Attached Thumbnails Isolate by Type Parameter-getanyparametervaluebyname.png   Isolate by Type Parameter-getanyparametervaluebyname-test.png
    October 11, 2012
    St. Louis
    403
    05:27 AM
    That makes perfect sense, thank you
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,143
    08:27 AM
    Quote Originally Posted by irneb View Post
    dumb question - what's the difference between the custom node you created here and similar nodes from Rhythm or similar? I can see the output is a little different, but otherwise is there a big difference?
    Attached Thumbnails Attached Thumbnails Isolate by Type Parameter-getparameter.png
    April 25, 2013
    Jo'burg SA
    350
    02:27 PM
    Nothing much, though I think those just do the same thing through Python (or perhaps C#) instead of Dyn nodes.
    My reason for posting it is just to show how it could be done "simply" if you didn't use such 3rd party libraries.
    amoursol and cellophane like this.
    April 25, 2013
    Jo'burg SA
    350
    02:27 PM
    That means there is some re-arrangement going on in that Rythim node. Looking at its source: https://github.com/sixtysecondrevit/RhythmForDynamo
    Seems to be written in C#. And it returns a Dictionary containing the name and value of the parameter. Not just the value itself. So the thing seeming to be multiple sub-lists is actually a dictionary (key/value lookup store) for each item in the inputs.
    Mine is just returning the param found and its value.
    August 9, 2011
    Louisville, KY
    6,143
    08:27 AM
    Thanks. Just curious on what the difference was. I also created my first custom node by recreating that
  1. Replies: 0
    Last Post: March 11th, 2016, 12:15 AM
  2. Type's parameter cannot recursively point to the type itself?
    By jeeenyuss in forum Architecture - Family Creation
    Last Post: March 27th, 2015, 06:02 PM
  3. Replies: 0
    Last Post: August 26th, 2013, 07:45 AM
  4. Including instance parameter in type parameter formula
    By sabari2504 in forum Architecture - Family Creation
    Last Post: August 12th, 2013, 02:54 PM
  5. select by parameter? curtain wall panels' materials by parameter, by type or family?
    By oompa_l in forum Architecture and General Revit Questions
    Last Post: January 24th, 2013, 02:20 PM
