Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By johnp
Thread: DYNAMO_Create CurtainSystem gridlines
    January 9, 2018
    1
    10:25 AM
    Hi all.
    I’m new to Dynamo and I need some help please.
    I’m trying to create a parametric curtain wall system by creating the mass in Dynamo, from a rhino 3D object, imported in Dyanmo by Rhynamo package.
    I started by importing the rhino 3D file through rhynamo, and than I created a family Mass by Springs.FamilyInstance.ByGeometry, and than I created a Curtain Wall System by Mass.
    I would want to create a grid layout and I use a ReAnimation package, with “CreateCurtainGrids” script…
    Is the procedure correct?
    Someone could suggest another solutions? Is it possible create a layout for add grid line or to create a curtain panels to adapt on family Mass surface?
    Can anyone help me please. Thanks
    S
    Member johnp's Avatar
    March 24, 2015
    148
    03:25 AM
    I also responded over at the Dynamo forum, but here is the same response.
    Yeah, Unfortunately, it seems like that node "Create Curtain Grids" expects a curtain wall element. You are going to need some additional nodes to do this with actual curtain systems..
    Essentially, we need to:
    1. Obtain the curtain grid element from the curtain system.
    2. Add the grid line by a given point (wombat or Rhythm has this portion already).
    I don't have the nodes created yet, but I might be able to get something created in my free time this evening.
    -John
    amoursol likes this.
  1. Dimensioning Gridlines
    By mdomer in forum Architecture and General Revit Questions
    Last Post: March 21st, 2016, 11:05 PM
  2. Overlapping Gridlines
    Last Post: March 14th, 2016, 05:02 PM
  3. In trouble with GridLines disappearing
    By Yan Naing Bo in forum Structure - General Questions
    Last Post: October 17th, 2011, 04:22 AM
  4. gridlines
    By elton williams in forum Architecture and General Revit Questions
    Last Post: October 13th, 2011, 06:58 PM
  5. Visible gridlines in assembly
    By Odemeer in forum Architecture and General Revit Questions
    Last Post: July 19th, 2011, 12:48 PM
