Results 1 to 2 of 2
Like Tree7Likes
  • 7 Post By cellophane
Thread: Create Window Types for Legend (Previous Phase) Views
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,164
    03:49 AM
    Sharing seems like the thing to do. I created a graph to create a wall, place window types used in the project, set everything to a legend phase and demolish it appropriately. This all assumes that you are using the previous phase method for your legends. User will need to verify the wall type, wall location (currently set to 0,100 / (window width sum*2),100), and phases.
    Enjoy.
    edit: the If node wasn’t working so it’s removed. also defined a function for Sill Height so it can be used in multiple places, in particular to define the height of the wall (Sill Height + Window Height + 3)
    Attached Thumbnails Attached Thumbnails Create Window Types for Legend (Previous Phase) Views-create-families-legends-window-legend.png
    Attached Files Attached Files
    April 8, 2016
    1
    07:49 AM
    hello. can you post an example of how it works. regards
  1. Legend Phase v Design Options
    By anthonyB in forum Architecture and General Revit Questions
    Last Post: August 9th, 2016, 12:47 AM
  2. converting drafting views to previous version revit
    By haydenrrr in forum Architecture and General Revit Questions
    Last Post: December 8th, 2015, 11:52 AM
  3. Duct Types in a Legend
    By mkicher in forum MEP - General
    Last Post: November 19th, 2013, 04:46 PM
  4. A window in new construction phase will not cut a wall which is in existing phase
    By Craig Howie in forum Architecture and General Revit Questions
    Last Post: May 24th, 2012, 05:33 AM
  5. Phase Filter Previous+Demo NOT showing my demo elements?
    By sebaldsl in forum Structure - General Questions
    Last Post: April 25th, 2012, 04:30 PM
