Results 1 to 4 of 4
Like Tree4Likes
  • 1 Post By johnp
Thread: Detail Level
    September 8, 2014
    India
    59
    04:50 PM
    Question Detail Level
    Hi all,
    Please help me I need Purlin in coarse(Detail Level) and other structural Framing categories like Girder, Joist, Chord, Vertical & Horizontal Bracing in Fine(Detail Level),
    Is it Possible using Dynamo?
    Member johnp's Avatar
    March 24, 2015
    148
    04:20 AM
    Element.Geometry+ from Clockwork package should help you out as it allows for detail level input, (as string).
    Attached Thumbnails Attached Thumbnails Detail Level-2017-12-18-08_02_11-dynamo.png
    amoursol likes this.
    November 21, 2012
    London, United Kingdom
    612
    11:20 AM
    Hello Dhilip,
    It appears it may be possible through the Options Class and Python. If you are comfortable with Python and the Revit API, go have a look at the DetailLevel Property under Autodesk.Revit.DB.Namespace -> Options Class -> Options Properties on the revitapidocs.com
    September 8, 2014
    India
    59
    04:50 PM
    hi JohnP,
    Thanks for Replying.
    I tried your Suggestion for several days with different methods but only the element colour is varying as shown in the attached Image.
    Can you please solve this Issue.
    hi amoursol,
    I don't know python Script
    Attached Thumbnails Attached Thumbnails Detail Level-dynamo-clockwork-script.png   Detail Level-revit-element.png
  1. Level of Detail in Architecture
    By MARIA1993 in forum Architecture and General Revit Questions
    Last Post: September 5th, 2017, 08:17 AM
  2. Facades and respective level of detail
    By Karalon10 in forum Architecture and General Revit Questions
    Last Post: June 24th, 2017, 01:24 PM
  3. Changing level of detail?
    By keith_eg6 in forum MEP - General
    Last Post: March 3rd, 2016, 03:08 PM
  4. Detail Level of objects
    By jean_francois_nant in forum Structure - General Questions
    Last Post: November 28th, 2013, 06:11 PM
  5. Level of Detail - HELP
    By domsib in forum MEP - General
    Last Post: June 25th, 2013, 11:08 AM
