Results 1 to 7 of 7
Like Tree3Likes
  • 2 Post By Mengelmn
  • 1 Post By Mengelmn
Thread: Dynamo List Sorting & Concatenating! I have the information, just wrong order! Help!!
    January 14, 2013
    4
    08:40 PM
    Hi i'm hoping someone can help me with this....?
    I have a basic schedule containing circuit information in revit like this...
    Ive done a dynamo script that gives me a list of the information i need to extract.
    what im trying to get to is a list that gives me the joined string of circuit number, rooms, comment.
    so based on the Revit schedule something reads like this:
    L11 - R.06/R.07/R.08/R.09/R.10/R.11 SP
    L12 - R.02/R.03/R.04/R.05/R.12/R.13 SP
    L21 - R.06/R.07/R.09/R.10/R.11 CL
    L31 - R.02/R.03/R.05/R.12/R.13 CL
    There are instances where there are 2 fixtures the same circuit in a room, but i dont want this room to be in the string twice.
    If anyone can help me with this i will be eternally grateful! i've wasting too much of my life on this already.
    Thank you in Advance!
    Script and revit file attached (2016).
    Attached Thumbnails Attached Thumbnails Dynamo List Sorting & Concatenating! I have the information, just wrong order! Help!!-revit-schedule.jpg   Dynamo List Sorting & Concatenating! I have the information, just wrong order! Help!!-list.jpg
    Attached Files Attached Files
    May 30, 2015
    201
    03:40 PM
    A little trouble following exactly what you are attempting to produce, but
    How are you extracting the data from Revit via Dynamo. Are you extracting the Schedule or the element data?
    Are you using rooms or spaces?
    Have you looked at “grouping by key”
    If you want each element to be an unique value, you will need another value, as based on your current information you would end up with duplicates.
    What you may have to do is combine the room values separately and then insert them into your concatenated values.
    If you can provide more clarity, maybe a image of your full graph more assistance could be provided.
    January 14, 2013
    4
    08:40 PM
    Hi Mengelmn,
    i'm extracting the element data into dynamo.
    im using spaces.
    what im trying to get to is the string of data mention in my OP, so i can push that back into another parameter as a circuit description.
    i do this normally by extracting the schedule into excel and sorting the data in there. but i wanted a more automated way without the excel export/import part.
    full image below...
    i have tried all sort, group by key, sort by duplicates, unique items.
    and i'm just getting round in circles getting variations of my final list..
    Thanks,
    Dan
    Attached Thumbnails Attached Thumbnails Dynamo List Sorting & Concatenating! I have the information, just wrong order! Help!!-circuits-script.jpg
    May 30, 2015
    201
    03:40 PM
    End of the day what you want is “circuit” + “list of spaces” + “comments”
    To do this you will need to first combine the “list” of spaces into a single value and then combine that with the circuit number and comments.
    Try grouping you list of space numbers by its circuit number, this should give you a list of the unique circuit numbers and a list of list containing the spaces. Each of the sub list you could then combine to a single value.
    Repeat the above with comments
    That should give you three equal list of equal length that you could then Combine to a single value.
    What this really means is you need to concat or combine your values multiple times to get to a single value.
    uaifestival and amoursol like this.
    January 14, 2013
    4
    08:40 PM
    Ok this is great! getting somewhere now!! thank you!
    i have my lists as you suggested (i think)...
    and now have a list of all the unique values that match the ones in the Revit schedule!
    now is there a way i can group together the rooms so the final string appears something like this..?
    instead of the 22 individual lines i have?
    Attached Thumbnails Attached Thumbnails Dynamo List Sorting & Concatenating! I have the information, just wrong order! Help!!-list-updated.jpg   Dynamo List Sorting & Concatenating! I have the information, just wrong order! Help!!-circuits-script-updated.jpg
    January 14, 2013
    4
    08:40 PM
    Ok i managed to get the list to where i want it to be!
    i need to get this this to replace the values in this second list.
    i realise i can probably do this with a n export/ import from excel.
    but can it be done in dynamo without the excel step?
    i've tried a few nodes but all giving me errors.
    any thoughts on if i can do this, and how?
    Thanks,
    Dan
    Attached Thumbnails Attached Thumbnails Dynamo List Sorting & Concatenating! I have the information, just wrong order! Help!!-list-loads-parameter.jpg   Dynamo List Sorting & Concatenating! I have the information, just wrong order! Help!!-list-loads-parameter.jpg
    May 30, 2015
    201
    03:40 PM
    Quote Originally Posted by landofdan View Post
    Thanks,
    Dan
    If you are looking to put this value back into Revit, then use the Set Parameter by Name block and you should be all set
    amoursol likes this.
  1. Sorting draw order for detail components with objects (families)
    By katewood1989 in forum Architecture and General Revit Questions
    Last Post: November 20th, 2017, 09:52 PM
  2. schedules and sorting information
    By mschirmer in forum Architecture - Family Creation
    Last Post: September 26th, 2017, 06:58 PM
  3. Property List Order Revit Family
    By MattKincaid in forum Architecture - Family Creation
    Last Post: February 10th, 2015, 04:19 PM
  4. Problem with toposurface tool connecting the elevation points in the wrong order.
    By simo8172 in forum Architecture and General Revit Questions
    Last Post: February 12th, 2014, 09:37 AM
  5. Replies: 0
    Last Post: January 20th, 2014, 03:16 AM
