Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By johnp
  • 1 Post By johnp
Thread: Element.Space with Conduit Fittings
    August 29, 2015
    95
    06:06 PM
    Hi!
    I want to get the Space from Conduit Fittings-elements. I have tried Element.Space from the Rhythm-package, but it does not work with Conduit Fittings. Do someone from you now how to solve the problem? Do you have a ConduitFittings.Space node to share?
    Best regards Engineer
    Member johnp's Avatar
    March 24, 2015
    149
    12:06 PM
    Hi! The method the Element.Space node uses actually only works for loadable families. I renamed the node recently to reflect this restriction.
    In order to get the space, a conduit fitting falls in, you could do something like this.
    Attached Thumbnails Attached Thumbnails Element.Space with Conduit Fittings-familyinstance.space.png   Element.Space with Conduit Fittings-2017-11-27-07_11_49-dynamo.png
    amoursol likes this.
    August 29, 2015
    95
    06:06 PM
    Thank you! Unfortunately I dont have the node Element.GetLocation, maby it is because I use old version of Dynamo. And I use Revit 2017.
    March 24, 2015
    149
    12:06 PM
    Ah I see. Clockwork also has a node for this, "Element.Location"
  1. Replies: 33
    Last Post: May 23rd, 2016, 03:05 PM
  2. Switching element type to Curtain element.
    By MPwuzhere in forum Architecture and General Revit Questions
    Last Post: February 27th, 2015, 10:07 PM
  3. Replies: 0
    Last Post: February 12th, 2015, 01:15 AM
  4. Replies: 0
    Last Post: December 4th, 2014, 11:15 AM
  5. Replies: 2
    Last Post: September 16th, 2014, 09:28 PM
