Results 1 to 3 of 3
Thread: Filter rooms by having or not parameters value
    Junior Member Aida Siala's Avatar
    October 25, 2017
    27
    11:36 AM
    Question Filter rooms by having or not parameters value
    Hello every body,
    could I have the indices of rooms having a parameter value successively without having recourse to select the values ( "AllIndicesOff" node),
    because items in this exemple are not unique
    Attached Thumbnails Attached Thumbnails Filter rooms by having or not parameters value-rf4.png
    May 30, 2015
    201
    05:36 AM
    What is your end goal? Would help to understand and reply - are you trying to get a count of each unique value ? “How many Cuisine?”
    October 25, 2017
    27
    11:36 AM
    I have a list of rooms access requirements, which are assigned by sroom sub-types.
    Eg. a "dining room" must be accessible from a "kitchen" (the project contains several dining rooms and several kitchens)
    My goal is to check if there is actually direct access between them.
    I am trying to do that :
    1- Have the list of dining rooms in the model
    2- Have the list of each dining room boundaries
    3- Have the list of the model kitchens
    4- Have the list of boundaries of each kitchen
    => check if each dining room contains a wall in common with all kitchens boundaries
  1. Replies: 0
    Last Post: November 15th, 2017, 02:24 PM
  2. Dynamo Filter, then set parameters
    By damo3 in forum Dynamo BIM
    Last Post: January 15th, 2017, 08:26 AM
  3. Replies: 0
    Last Post: August 27th, 2015, 12:15 AM
  4. Rooms inside rooms... best practice?
    By Jaime in forum Architecture and General Revit Questions
    Last Post: July 31st, 2014, 12:36 PM
  5. Replies: 0
    Last Post: July 28th, 2014, 08:15 PM
