Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By cellophane
Thread: Create shared parameters in Revit with Dynamo
    Junior Member Aida Siala's Avatar
    October 25, 2017
    27
    05:51 PM
    Exclamation Create shared parameters in Revit with Dynamo
    Hi guys!
    I am trying to create shared parameters from an Excel file to add them to the project
    But, the node does not work
    how should I proceed?
    Find the Dynamo and Excel files attached.
    Attached Thumbnails Attached Thumbnails Create shared parameters in Revit with Dynamo-capturedf.png
    Attached Files Attached Files
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    12:51 PM
    If you look at the error message on the node it can provide some good information. In this case it is looking for a certain type of input in the form of: array; array; array; string; string; Revit Categories. You can skip 3 of the nodes you have and get almost there. The other error that will pop up is about an invalid parameter type. Double check your spreadsheet - there are some spelling & capitalization errors
    Attached Thumbnails Attached Thumbnails Create shared parameters in Revit with Dynamo-errormessage-nodeinput.png   Create shared parameters in Revit with Dynamo-errormessage-invalidtype.png
    amoursol likes this.
    October 25, 2017
    27
    05:51 PM
    Thank you for the quick reply,but, it doesn't work yet
    It can not find the shared parameters file (though I created a new one!)
    Attached Thumbnails Attached Thumbnails Create shared parameters in Revit with Dynamo-rf3.jpg
    February 7, 2013
    1
    12:51 PM
    Hi Aida,
    First of all thanks for the above screenshots - they helped me get the right nodes in place to make this script work.
    Theres a node called 'Parameter.SharedParameterFile" (top right) - I think it just reads the location of your .txt file in Revit (make sure you have one loaded) and then writes back to it.
    You can see the Revit window on the left - it wrote my new Shared Parameter and I can now use it. Writing a script to apply the new shared parameter to REvit families is my next task.
    Attached Thumbnails Attached Thumbnails Create shared parameters in Revit with Dynamo-2018-03-21-11_41_44-greenshot.jpg
  1. Replies: 0
    Last Post: September 11th, 2017, 02:15 PM
  2. Replies: 1
    Last Post: August 30th, 2016, 04:00 PM
  3. Replies: 2
    Last Post: January 16th, 2016, 05:42 PM
  4. Replies: 0
    Last Post: May 30th, 2015, 01:16 AM
  5. Import shared parameters into an existing shared parameters file
    By Ree in forum Architecture and General Revit Questions
    Last Post: January 14th, 2013, 10:34 PM
