Results 1 to 10 of 10
Like Tree9Likes
  • 3 Post By DaveP
  • 2 Post By cellophane
  • 2 Post By DaveP
  • 2 Post By cellersick
Thread: Where is Sheet 0,0?
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    03:56 PM
    Where is Sheet 0,0?
    I've got a graph that looks at all the Viewports on a Sheet and adjusts the Detail Number based on where they are on the Sheet
    I added a section to look at where the Titleblock is in case it got moved, but every time I've looked at it, the Titlebock is at 0,0
    So I'm wondering if I even need to worry about that, or can I just assume the Titleblock is ALWAYS at 0,0
    May 18, 2011
    Calgary, AB
    399
    02:56 PM
    A little testing.
    Lower left corner is 0,0 in the titleblock family.
    Create a new sheet and 0,0 of the family will match 0,0 of the sheet.
    So unless someone adjusts the linework in the family, or physically moves the titleblock in the sheet, 0,0 will always match.
    Might be a valid check for the 0.01% of the time, just in case.
    What happens if you didn't have the check? Could you catch the error visually?
    January 10, 2011
    St Paul, MN
    2,980
    03:56 PM
    OK, I stopped being lazy and tested it myself (just thought, maybe someone would know off the top of their head)
    For future reference, the Titleblock is NOT always at 0,0.
    I checked one that had been created from "New Sheet" and it was, as expected, at 0,0
    Then I selected the Titleblock family and moved it an inch to the right.
    Ran the graph again, and it reported X=0.083, which is an inch in decimal feet.
    So, in answer to my own question, yes I do need to test the location. Just in case someone did something goofy and moved everything, including the Titleblock
    johnp, cganiere and amoursol like this.
    May 18, 2011
    Calgary, AB
    399
    02:56 PM
    ...(just thought, maybe someone would know off the top of their head)
    I must be using that invisible font again...
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    04:56 PM
    I adjusted my title block insert location from bottom left to bottom right a while back and unsurprisingly it caused some issues in projects. So I made a graph to move all of the title blocks to 0,0 (see attached.) Still requires someone to move views that are wrong, but its as simple as selecting all the views and moving them the X distance of the title block (36", 42", 48".) And manual checking is good for you sometimes.
    https://www.revitforum.org/dynamo-bi...locations.html
    Attached Thumbnails Attached Thumbnails Where is Sheet 0,0?-settitleblocklocation.png
    Attached Files Attached Files
    10,178
    03:56 PM
    Not sure why that caused issues. My titleblocks origin is the top right of the viewport space (not absolute edge) and has been for years.
    Zero issues.
    Aaron Maller
    Director
    Parallax Team, Inc.
    January 10, 2011
    St Paul, MN
    2,980
    03:56 PM
    I guess I should share.
    My graph is attached below
    All required Packages are documented in orange in the upper left.
    I've got one Custom node that writes a log file of who used it and when, but that's not required. If anyone wants that, I'd be happy to share it, too.
    There's a Code Block that's at the core of the whole thing.
    The first Item in the list is a list of X values that determine where the Zones are.
    Second item is the first part of the Detail Name
    Third and fourth do the same for the Y values.
    Based on where the lower left of the Detail bubble lands, the Detail Number is changed to the corresponding Zone : 1A, or 3F, up to 8H
    Standing on the shoulders of giants, the core of this graph is based on Nate Holland's AU 2015 presentation
    https://vimeo.com/150452601#t=41m15s
    johnp and amoursol like this.
    March 21, 2013
    Phoenix, AZ
    275
    01:56 PM
    Quote Originally Posted by cheinaranta View Post
    I think you're joking, but you can actually find that here:
    invisible font a true type font for windows where the characters are not displayable or printable
    (above his signature he notes that it is freeware, so you could distribute it with the model if you need to)
    and..ummmm..... that's one of my tricks for getting color fill legend swatches to match heights with schedules.
    elton williams and amoursol like this.
    May 18, 2011
    Calgary, AB
    399
    02:56 PM
    Yes, my sense of humour doesn't come across very well in text... it's much dryer and much more sarcastic...
    Interesting hack with the colour swatches.
    August 9, 2011
    Louisville, KY
    6,140
    04:56 PM
    Quote Originally Posted by cellersick View Post
    ...tricks for getting color fill legend swatches to match heights with schedules.
    If you select the legend and edit type you can change the font size, color and type
  1. Adding Sheet Numbers and Sheet Indexes
    Last Post: October 3rd, 2017, 09:08 PM
  2. Sheet Number reporting parameter inside family used on sheet
    By Kaducki in forum Architecture - Family Creation
    Last Post: July 14th, 2017, 02:40 PM
  3. Sheet Revison and revision clouds in the sheet
    By quocviet0327 in forum Tutorials, Tips & Tricks
    Last Post: July 28th, 2015, 03:04 AM
  4. Sheet list - How can I add a circle or dot parameter relating sheet names to phases?
    By yral87 in forum Architecture and General Revit Questions
    Last Post: May 18th, 2015, 07:48 PM
  5. Sheet just became a Detail View, but still listed in Sheet List
    By LeanneZ in forum Architecture and General Revit Questions
    Last Post: February 25th, 2011, 09:25 PM
