Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By DanielHurtubise
Thread: How to get indices of emty lists
    Junior Member Aida Siala's Avatar
    October 25, 2017
    27
    04:31 AM
    Hello!
    I am checking if rooms in Revit receive daylight and want to display this information in Revit.
    - How can I get the indices of empty lists of "Room.Windows" node?
    - And how can I display rooms without daylight in red color in Revit plan?
    Attached Thumbnails Attached Thumbnails How to get indices of emty lists-en.png
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,423
    09:31 PM
    One of the tricks I've found recently is "get keys" creates a list of index numbers, so using a bool filter (is empty list perhaps) and the key list you should get a list of indexes.
    I haven't tried doing the later so I don't have any practical experience. It would depend on whether you want it to be permanent or temporary. I'd approach by writing to a parameter in the rooms that I can use to apply a color scheme, but I know there are pure Dynamo methods out there.
    February 2, 2011
    Montreal/Paris
    830
    10:31 PM
    Comme ca ca devrait le faire
    cellophane likes this.
    October 25, 2017
    27
    04:31 AM
    Thank you so much
    February 2, 2011
    Montreal/Paris
    830
    10:31 PM
    Always a pleasure
  1. Questions on Lists and Item Creation
    By Bdcoll in forum Dynamo BIM
    Last Post: January 21st, 2016, 04:33 PM
  2. Sheet Lists and revision sequence
    By Mel in forum Architecture and General Revit Questions
    Last Post: September 8th, 2015, 05:51 PM
  3. Master Sheet Lists
    By ThatBIMGuy in forum Architecture and General Revit Questions
    Last Post: May 8th, 2013, 02:15 PM
  4. Predefined Lists and ways to use them
    By SuperDave in forum Architecture and General Revit Questions
    Last Post: December 5th, 2012, 01:37 AM
  5. Import key lists
    By Carin in forum Tutorials, Tips & Tricks
    Last Post: November 20th, 2012, 06:08 AM
