Results 1 to 1 of 1
Thread: Checking rooms setted parameters values in Revit by Dynamo
    Junior Member Aida Siala's Avatar
    October 25, 2017
    27
    05:43 PM
    Hello,
    I worked on dynamo to integrate the program requirements on spaces into Revit (using "Element.SetParamerterValueByName").
    I am trying now to check them.
    I started with the simplest requirements which are the program area and the contiguity between two spaces.
    1/ I already checked the model rooms area with the program area. Now, how can I display in Red rooms in Revit which does not satisfy this requirement?
    2/ For the contiguity requirement, the rule is to check if the space in question has a wall in common with one of the spaces of the mentioned space Sub-Type in the program (find the program Excel file attached).
    I could only get the rooms having this requirement from Revit parameters and the bounding walls of all rooms of the model. But I don’t know how I can check them!
    Can someone help me please?
    Attached Thumbnails Attached Thumbnails Checking rooms setted parameters values in Revit by Dynamo-im1.jpg   Checking rooms setted parameters values in Revit by Dynamo-im2.jpg
    Attached Files Attached Files
  1. Replies: 0
    Last Post: November 23rd, 2015, 04:45 AM
  2. Replies: 0
    Last Post: November 16th, 2015, 01:15 PM
  3. Revit Kid: Practical Dynamo - Apply Parameter Values
    By The Revit Kid in forum Blog Feeds
    Last Post: November 9th, 2015, 03:45 PM
  4. Create 3D rooms in Revit with Dynamo
    By ChristianVE1991 in forum Dynamo BIM
    Last Post: October 22nd, 2015, 09:34 AM
  5. Replies: 0
    Last Post: July 28th, 2014, 08:15 PM
