Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By cheinaranta
Thread: Split Floor
    May 18, 2011
    Calgary, AB
    399
    05:16 AM
    Question Split Floor
    Trying to split a floor and following along using Marcello's graph from AU.
    I don't know why it's breaking down. Any ideas? Using Dynamo 1.3.2.0
    Attached Files Attached Files
    May 18, 2011
    Calgary, AB
    399
    05:16 AM
    I had some legends messing things up. If I put a "Select Model Element" so I can select the split line, then hooked that node up to Element.Geometry, that cleaned it up a bit and things ran smoother.
    amoursol likes this.
  1. Floor Based Family: Floor Grate. Works fine UNTIL I array the grid
    By doni49 in forum Architecture - Family Creation
    Last Post: August 19th, 2015, 09:36 AM
  2. Split floor levels - best practice
    By john.warburton in forum Architecture and General Revit Questions
    Last Post: March 2nd, 2015, 02:51 PM
  3. Split Floor Surface Pattern
    By mark b in forum Tutorials, Tips & Tricks
    Last Post: August 13th, 2013, 11:14 PM
  4. Split Face & Paint vs Modeled Floor Finishes
    By kirklyncox in forum Architecture and General Revit Questions
    Last Post: August 20th, 2012, 07:10 AM
  5. Split floor into sections
    By JasonWallis in forum Architecture and General Revit Questions
    Last Post: December 21st, 2011, 06:22 AM
Tags for this Thread
