Results 1 to 10 of 10
Like Tree14Likes
  • 1 Post By johnp
  • 1 Post By ScubaMan
  • 2 Post By johnp
  • 2 Post By ScubaMan
  • 3 Post By Yna_Db
  • 3 Post By Yna_Db
Thread: Is there an easy to know which packages i'm using in a particular graph?
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    403
    12:15 AM
    If i create a complex graph for someone and send it to them, sometimes they don't have the right packages installed. is there an easy to for Dynamo to know which packages are being used in the graph and notify me or do i need to troubleshoot each time.
    Thanks,
    Member johnp's Avatar
    March 24, 2015
    149
    01:15 AM
    (Revised, see scubaman's answer) U̶n̶f̶o̶r̶t̶u̶n̶a̶t̶e̶l̶y̶ ̶n̶o̶.̶ ̶N̶o̶t̶ ̶a̶t̶ ̶t̶h̶i̶s̶ ̶t̶i̶m̶e̶.̶ ̶ Typically I see users make sure to annotate their graph well with the packages used.
    Last edited by johnp; November 8th, 2017 at 05:21 PM. Reason: revised for ScubaMan's answer
    amoursol likes this.
    Member ScubaMan's Avatar
    July 6, 2015
    201
    12:15 AM
    There is a way but not sure how Josh Moore and Justin Benjamin accomplished it. I think they wrote a dynamo script to open the text version of their scrips and got the names of the nodes and then mapped it to the package. Not sure though just know they did it. You can see there AU presentation at the link below. Checkout the handout provided and go to page 14 and 15.
    Everyday Dynamo: Automating Simple Solutions That Bridge Workflow Gaps Within Revit
    Sorry I cannot be more help than yes someone has done it someway.
    Steven
    johnp likes this.
    March 24, 2015
    149
    01:15 AM
    Quote Originally Posted by ScubaMan View Post
    Steven
    Yeah, there are ways around it and that is super clever. But, I would rather just annotate my Dynamo graphs (code) correctly in the first place. When building reusable stuff like Dynamo graphs, it is always nice to "keep an eye out for the next guy/gal".
    elton williams and cganiere like this.
    July 6, 2015
    201
    12:15 AM
    I would agree johnp. We should keep an eye out for what nodes we are adding but sometimes its hard. This will help to know what you have added with ease and allow for a double check. Some times I miss a node.
    There may be a better way to do this but this is what I cam up with over lunch. It list all the nodes as well but they are just the OTB one so I just filtered them out. Let me know what you think.
    Attached Thumbnails Attached Thumbnails Is there an easy to know which packages i'm using in a particular graph?-nodes-script.png
    Yna_Db and cellophane like this.
    September 19, 2015
    163
    08:15 AM
    This is very nice indeed. I tried to improve it a little to simplify the file names extraction from the "packages" Directory. The number of packages is still greater than the number of nodes, I will need to check why, along with a couple of other details.
    Attached Thumbnails Attached Thumbnails Is there an easy to know which packages i'm using in a particular graph?-nodes-packages-use.png
    ScubaMan, cellophane and johnp like this.
    July 6, 2015
    201
    12:15 AM
    Really like what you did here. Great improvement. Thanks for reposing
    Attached Thumbnails Attached Thumbnails Is there an easy to know which packages i'm using in a particular graph?-capture.png
    Yna_Db and cganiere like this.
    September 19, 2015
    163
    08:15 AM
    I finally think getting the nodes paths would suffice to collect all useful information (the only point is that I don't see how to access the Zero Touch nodes list).
    Edit: I also see that some custom nodes still do not appear in the final list [...]
    Attached Thumbnails Attached Thumbnails Is there an easy to know which packages i'm using in a particular graph?-nodes-filepaths.png
    July 6, 2015
    201
    12:15 AM
    Unfortunately my knowledge of zertouch nodes is limited. I have been slowly reading up on them. Looks like now is a good time to try and figure them out.
    When you say some custom nodes are not appearing what ones are they. Are they in the bin folder or another one?
    September 19, 2015
    163
    08:15 AM
    I have decided to post my last graph on the Dynamo Forum to see if any improvement could be done. See:
    https://forum.dynamobim.com/t/find-n...-a-graph/16367
    I have extracted the name of the node directly in the header of the file because it is sometimes different from the name of the file itself, and that's why all custom nodes did not appear in my final list. It's late here already but I will be happy to read any contribution tomorrow...
  1. My Very First Dynamo Graph (no laughing...)
    By Twiceroadsfool in forum Dynamo BIM
    Last Post: January 11th, 2017, 01:06 PM
  2. Dynamo Packages.com down today? (05/16)
    By DaveP in forum Dynamo BIM
    Last Post: May 16th, 2016, 08:06 PM
  3. Compatible packages
    Last Post: February 2nd, 2016, 06:29 PM
  4. Structural Building Design packages
    By jh75 in forum Structure - General Questions
    Last Post: July 6th, 2015, 03:15 AM
  5. Drawing List for different packages
    By billiam in forum Architecture and General Revit Questions
    Last Post: December 4th, 2013, 04:10 PM
