Results 1 to 3 of 3
Thread: Reset overrides in area plans
    April 12, 2011
    Chicago, IL
    523
    09:42 PM
    I've got a dynamo graph that checks a value against a max value and turns the object red if the max is exceeded. I'd also like it to be able to reset the overrides if a previous violator is now below the max. I'm using the clockwork nodes and they seem to work fine in normal views, but the reset doesn't work in area plans. I'm using the area plans to populate the max values, so I'd like to find a way to have this work without changing views if possible. Anyone else run into this before? I know I can just override them to black instead, but that seems like a cheat.
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    319
    04:42 AM
    Quick test seems to work with the Springs.Doc.ActiveView Node:
    https://www.screencast.com/t/mESiBXCBK
    I'm overriding Area's because you mentioned an Area Plan? If this doesn't work, what elements are you overriding?
    April 12, 2011
    Chicago, IL
    523
    09:42 PM
    The springs active view did the trick. I was using the clockwork active view node and that seems to be a little more limited. This is for egress paths. I'm using the area plan to set maximum travel distance based on where they exist in the model and then comparing the max travel to the actual travel, turning any that exceed the max red.
    Thanks for the help!
  1. Using area plans instead of floor plans
    By Whatuser in forum Architecture and General Revit Questions
    Last Post: June 4th, 2018, 01:00 AM
  2. Area Plans and Phasing ?
    By Munkholm in forum Architecture and General Revit Questions
    Last Post: January 2nd, 2017, 05:25 PM
  3. Area plans used for all floor plans?
    By joeyd in forum Architecture and General Revit Questions
    Last Post: April 6th, 2015, 06:46 PM
  4. View Refernces with Area Plans?
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: February 12th, 2015, 07:39 PM
  5. Room Tags & Area Plans
    By Karstileigh in forum Architecture and General Revit Questions
    Last Post: April 11th, 2013, 03:02 PM
