Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By Yna_Db
  • 1 Post By cftrevizo
Thread: Remapping Texture Locations
    January 19, 2012
    322
    08:12 AM
    New to Dynamo, I'm focusing on tasks involving remapping. Looking into implementation strategies for when the office finally gets out of the old habits that causes the excess of the 256 character limit issues on the server when backups need to happen. Has anyone dealt with remapping the Texture paths to Materials using Dynamo, can it be accessed?
    Member ScubaMan's Avatar
    July 6, 2015
    199
    06:12 AM
    Whoops I had two posts open and accidentally posed on this one. I am sorry. Please ignore my comment.
    September 19, 2015
    163
    02:12 PM
    PolynineStudio likes this.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    09:12 AM
    Are you remapping the appearance paths in the options or looking for actual texture map location?
    January 19, 2012
    322
    08:12 AM
    Remapping appearance maps in the options. So I merged the OOTB materials with my own custom stuff into a server location (& renamed some just to test different workflows with remapping too in case updated nomenclature is desired). I think Yna_Db is close, & just need to translate that into the nodes of Dynamo.
    December 21, 2010
    C.LONDON
    4,353
    02:12 PM
    I shall be following this thread with interest.
    January 19, 2012
    322
    08:12 AM
    Well, I got it to export to Excel the Materials & associated Assets. Now bringing it back home with the new names. If someone can point me to some good resources to reference & or pointers...that'd be great.
    August 9, 2011
    Louisville, KY
    6,104
    09:12 AM
    I was going to point you to the DynamoForum post I made on this a while back but I see you found that. (For everyone else: https://forum.dynamobim.com/t/material-asset-names/4824)
    That said - I haven't had much luck pushing Assets back into Revit. I did get materials out to excel, renamed them there, and pushed back into Revit. Also deleted a bunch I didn't want by adding a prefix, then using Dynamo to delete everything with that prefix. I know the materials API is still pretty restricted... (https://forum.dynamobim.com/t/new-ma...roject/11030/9)
    January 19, 2012
    322
    08:12 AM
    Right, I believe with Revit 2018.2 it's starting to open it up some. I'm looking at a node called "Material.Properties" & trying to learn if the Code Yna_Db referenced can be incorporated. Got homework to do getting more familiar with Python.
    January 19, 2012
    322
    08:12 AM
    Yna_Db likes this.
  1. Titleblock Locations
    By cellophane in forum Dynamo BIM
    Last Post: June 26th, 2018, 01:54 PM
  2. BIM Opportunities - Various Locations
    By Jonojnr in forum Career Corner
    Last Post: May 22nd, 2015, 03:23 PM
  3. Family Locations
    By ESD ltd in forum Architecture and General Revit Questions
    Last Post: November 14th, 2014, 05:26 PM
  4. Worksharing from remote locations
    By log in forum Worksharing, Revit Server & C4R
    Last Post: June 4th, 2014, 03:12 AM
  5. Locations of Equipment
    By domsib in forum MEP - General
    Last Post: April 12th, 2013, 03:27 PM
