Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Bjorn_K
Thread: Create rooms by name and number
    Junior Member Aida Siala's Avatar
    October 25, 2017
    27
    05:32 PM
    Hello,
    I am a beginner in Dynamo and I have a simple question.
    I am working with Revit 2017 and dynamo 1.3.2 and using Lunch Box package to create rooms by name and number.
    But, the list of new rooms in Revit does not match the return value in dynamo! There are also as duplicated rooms as runnings.
    Attached Thumbnails Attached Thumbnails Create rooms by name and number-capturef.png   Create rooms by name and number-cap2.png   Create rooms by name and number-cap3.png
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    12:32 PM
    Have you looked at the lacing?
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    313
    06:32 PM
    With only the screenshots to look at, it seems you left the Boolean Toggle on True while testing/rewiring your script. (and thus destroying the element binding) Do you get the same result in a blank Revit file if you just let the script run once?
    Why are you not cleaning the "null" values from your name and number lists? With only 14 actual values there are now 16 Rooms created, resulting in all the None Rooms.
    Can't really tell anything else without the .dyn/.rvt (and maybe excel file?)
    amoursol likes this.
    October 25, 2017
    27
    05:32 PM
    Yes indeed, I forgot the Boolean Toggle on true!
    It's ok now, I've also removed the null values
    Thank you so much.
  1. Uniformat number for Rooms?
    By DaveP in forum Architecture and General Revit Questions
    Last Post: February 15th, 2017, 09:25 PM
  2. Create 3D rooms in Revit with Dynamo
    By ChristianVE1991 in forum Dynamo BIM
    Last Post: October 22nd, 2015, 09:34 AM
  3. Replies: 0
    Last Post: October 21st, 2015, 02:15 AM
  4. Create 3D Rooms in Revit Using DynamoBIM
    By Simply Complex in forum Blog Feeds
    Last Post: October 5th, 2015, 12:15 AM
  5. NEW PROJECT File>Create room>Room number is three. Want it to start at 1.
    By doni49 in forum Architecture and General Revit Questions
    Last Post: June 29th, 2013, 03:57 AM
