Results 1 to 2 of 2
Like Tree5Likes
  • 4 Post By cheinaranta
  • 1 Post By cheinaranta
Thread: Adding User Selected Revisions to User Selected Sheets
    May 18, 2011
    Calgary, AB
    383
    10:32 PM
    A few months ago I included a graph that would pull the last revision and add the revision based on selecting the sheets. I've used it many times with success. I had a project that had multiple bid packages, long story short, I needed to select which revision (not necessarily the last one) was going to go to which set of sheets. I think this is an improvement over the old one giving more flexibility found here.
    Dynamo: 1.2.1.3038
    Packages needed: Spring Nodes and Archi-lab.net
    Setting the Boolean to False and running the graph will reset the selections. Switch to true and reselect the sheets, then run.
    Attached Thumbnails Attached Thumbnails Adding User Selected Revisions to User Selected Sheets-revision_20171006.png
    Attached Files Attached Files
    May 18, 2011
    Calgary, AB
    383
    10:32 PM
    There is also a node called "Remove Revision from Sheet". Just had to use it because I got a little revision happy
    amoursol likes this.
  1. Adding Revisions to User selected Sheets
    By cheinaranta in forum Dynamo BIM
    Last Post: March 29th, 2017, 06:57 PM
  2. Replies: 1
    Last Post: February 2nd, 2017, 02:00 PM
  3. Print Selected Views/Sheets lockups
    By anthonyB in forum Architecture and General Revit Questions
    Last Post: November 4th, 2014, 05:04 AM
  4. print selected sheets command prints border with all texts
    By spotless in forum Architecture and General Revit Questions
    Last Post: December 14th, 2011, 05:41 PM
