Results 1 to 5 of 5
Like Tree4Likes
  • 3 Post By amoursol
  • 1 Post By ScubaMan
Thread: List Clean on Another List
    Member ScubaMan's Avatar
    July 6, 2015
    199
    12:47 AM
    Good day all,
    Is there a way to use List.Clean and know which list items were removed so I can remove the same items from another list?
    Thanks for you help,
    Steven
    July 6, 2015
    199
    12:47 AM
    Something like List.Clean.ByKey
    How you can sort list by a key can I clean them by one?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,124
    03:47 AM
    Don't know an answer but these should help:
    SortByKey
    Clean
    There are also a number of custom list management nodes - I know Grimshaw & Rhythm both have several.
    November 21, 2012
    London, United Kingdom
    612
    08:47 AM
    This is one way to do it!
    Attached Thumbnails Attached Thumbnails List Clean on Another List-revitforumquery_getitematindex.jpg
    cganiere, ScubaMan and josephpeel like this.
    July 6, 2015
    199
    12:47 AM
    Thanks Amoursol and Cellophane,
    Unfortunately due to the complexity of the list your way does not work easily Amoursol.
    For my solution I broke it into three chuck with some script slow down but not too bad.
    Capture 1:
    List information coming out of Springs.Collector.ElementsInView is in Level @2. Empty Lists are are returned at level @3 and @2. I wish to keep this list structure because the @3 is the sheet and @2 are the views on the sheet.
    List.Clean works great to clean the list but there is no way to clean the original list coming out of List.AddItemToFront.
    Capture 2:
    Since there is no way to match the lists I use Clockworks Element.OwnerView.
    Capture 3:
    I then need to know what sheet the views are on. Since you cannot fine what sheet a legend is on this is what I came up with. Grab the First view in each of the filtered list and then cross compare them against each list to find matching elements. I can then pull the first element (the sheet) from the original list coming out of List.AddItemToFront in Capture 1.
    The cross product on Contains slows things down a little bit but the script is already slow because of Springs.Collector.ElementsInView. So whats a few more seconds anyway.
    Not the best way to go about it but it does work and I could not spend any more time on it. I may venture back and clean it up one day. This was my attempt to find a better way to export revision clouds than I had achieved before. Seems to be faster and work better. Previous Cloud Exporter
    Thank for your help and suggestions,
    Steven
    Attached Thumbnails Attached Thumbnails List Clean on Another List-capture.png   List Clean on Another List-capture2.png   List Clean on Another List-capture3.png
    amoursol likes this.
  1. List of Views from List of View Names?
    By ryntau in forum Dynamo BIM
    Last Post: September 18th, 2017, 02:16 AM
  2. Detail item list not show full list (2017)
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: November 18th, 2016, 02:41 PM
  3. RTC: Hot List!
    By RTC in forum Blog Feeds
    Last Post: September 20th, 2016, 05:15 AM
  4. Replies: 0
    Last Post: March 12th, 2015, 06:16 AM
  5. Sheet List
    By Shields08 in forum Architecture and General Revit Questions
    Last Post: April 1st, 2014, 04:59 PM
