Results 1 to 7 of 7
Like Tree7Likes
  • 2 Post By ryntau
  • 2 Post By ScubaMan
  • 3 Post By amoursol
Thread: View Filter Overrides
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    01:09 PM
    How would I go about setting View Filter Overrides? I've seen a couple threads that all use stuff from Archi-Labs but they are not in the current version. In particular I'm looking at the View.OverrideGraphicSettings node - I (think) I can figure out the rest of it.
    https://forum.dynamobim.com/t/view-s...-not-work/8401
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    401
    10:09 AM
    If you trying to turn off certain categories, I just discovered this node in a package called MEPover.
    "View.SetCategoryVisibility"
    not the same as View Filter, but it might help someone out
    Attached Thumbnails Attached Thumbnails View Filter Overrides-viewsetcategory.png
    amoursol and cellophane like this.
    August 9, 2011
    Louisville, KY
    6,104
    01:09 PM
    Quote Originally Posted by ryntau View Post
    Nice one! That will definitely be useful, just not in this particular instance
    Member ScubaMan's Avatar
    July 6, 2015
    199
    10:09 AM
    Cellophane,
    Sorry for the late reply I was board and going through the forums. I think you will want to look at these to nods.
    Hope this helps,
    Steven
    cellophane and rytebim like this.
    November 21, 2012
    London, United Kingdom
    612
    06:09 PM
    Konrad has added those nodes to Core now - simply look under the Elements section The syntax is slightly different, but the overall is pretty much the same.
    cellophane, ScubaMan and rytebim like this.
    August 9, 2011
    Louisville, KY
    6,104
    01:09 PM
    Quote Originally Posted by ScubaMan View Post
    Cellophane,
    Hope this helps,
    Steven
    So the flip side of the original question: How can I set the filters to a No Override state if there is already a color / line weight override? ?
    Attached Thumbnails Attached Thumbnails View Filter Overrides-viewfiltersoverride.png
    Junior Member kraftwerk's Avatar
    November 1, 2012
    St. Louis, MO
    29
    12:09 PM
    The View Class has a Remove Filter member. That may be a start. I am shooting from the hip though.
    RemoveFilter Method
  1. Replies: 17
    Last Post: June 19th, 2017, 06:12 PM
  2. Replies: 0
    Last Post: March 8th, 2017, 06:15 AM
  3. Replies: 0
    Last Post: March 8th, 2017, 05:45 AM
  4. Graphic overrides by view- instance
    By sdbrownaia in forum Architecture and General Revit Questions
    Last Post: November 12th, 2015, 01:44 AM
  5. Saving V/G Overrides in every View?
    By tzframpton in forum Architecture and General Revit Questions
    Last Post: January 18th, 2012, 07:44 PM
